Could I use ngc file in defferent ise version
If I use different ise version generated ngc file,ISE8.2 and ISE10.1.
The NGC files have the same human-readable header:
XILINX-XDB 0.1 STUB 0.1 ASCII
XILINX-XDM V1.4e
Could I use the ngc file generated by ISE10.1, copy it to ISE8.2?
I don't know the XILINX-XDM mean what? If the XDM version is same, Then it could croos different ISE version?
Very appreciate your answer!
Re: Could I use ngc file in defferent ise version
O(∩_∩)O~
Community Manager
Community Manager
I would expect tools to be compatible in a forward manner.8.2 ngc to be used in 10.1 .
But its is always best to regenerate for the version that you are using.
O(∩_∩)O~
