Newbie rajesh877
Counter Sync between two different CPLD devices
We have to different CPLD's ( Same Part number ) on one single PCB. We provide clock to both the CPLD's using a single Crystal (8.192Mhz). In each CPLD we generate counters (5 bit counter ). We want the counters to run Synchronously. Our current issue is the counters ( on Both the CPLD's ) run asynchronously.
Request expers to provide us a solution to the above mentioned issue.
Scholar u4223374
Re: Counter Sync between two different CPLD devices
The obvious solution is to designate one CPLD as the "Master" and have it output a signal every time its counter overflows. This then resets the other CPLD's counter, forcing them to stay synchronized.
Newbie rajesh877
Thanks for immediate reply. We will try and update it here.
@rajesh877
Any update on this thread?
--Syed
