Visitor hardy
Critical Warning during Implementation of picxo v2.6 pre_opt.tcl
Hi, when i use the picxo(v2.6) , it has some critical warnings . I didn't restrict the picxo;   Dose these warnings effect the picxo's work?
notes: the vivado 2016.1
pre_opt.tcl :
[vivado 12-3346] could not propety 'LOCK_PINS' on instance U_xx/U_xx/U_xx/PICXO_FRACXO_0_i/U0/inst_picxo_top/obsawdkjh4ob/obsaiuran4bscm4fvcd. The cell is placed at the SLICE_X354Y120. The cell already has a "LOCK_PINS" property. please unplase the cell and reset the property prior to applying anew value.[lin:636]
[vivado 12-3346] could not propety 'LOCK_PINS' on instance U_xx/U_xx/U_xx/PICXO_FRACXO_0_i/U0/inst_picxo_top/obsawdkjh4ob/````. The cell is placed at the SLICE_X354Y120. The cell already has a "LOCK_PINS" property. please unplase the cell and reset the property prior to applying anew value.[lin:636]
Re: Critical Warning during Implementation of picxo v2.6 pre_opt.tcl
Do you get these warning when you open the implemented design?
Or when you run implementation?
If they occur when you open the implemented design, you can just ignore them.
Visitor hardy
ok,they occur when I open the implemented design.thanks
