Custom AXI IP with additional I/O ports: how to add I/O ports apart of AXI M/S interface ?
Once I create a custom AXI IP, I am trying to understand how do I add, from Vivado IP Packager, additional I/O ports to my IP.
From IP Packager, I can see I can add an interface and then map the Interface Logical Ports to IP's Physical ports, but I don't what to map ports to others, I would like to add them to the IP.
Example: suppose I have an AXI slave IP. After writing a certain value to one of its registers, I would like to toggle an output pin (could be a signal reset for another IP or anything else, no matter what). How do I do this ? Do I have to edit my custom AXI IP VHDL, xml and other related files ?
Thank you in advance for any suggestion.
Simon
Re: Custom AXI IP with additional I/O ports: how to add I/O ports apart of AXI M/S interface ?
Hi @simozz,
You can only modify your VHDL. The ports of the top level should correspond to the ports of your IP.
Florent
Florent
Hi @simozz,
Florent
Florent
Great. Thank you @florentw.
Simon
I have a problem where I have added an input port to the top level VHDL using "Edit in IP Packager" but the port does not show up in the Block Design (when back to the main project level) nor the component.xml file.  There are no error messages and synthesis gives no errors.  Any ideas as to what might be happening?  This worked when editing a different block.
I ended up having to edit the component.xml file to add the port, taking an educated guess on the formatting.  Seemed to work.
