jeongho80.kim
[DRC 23-20] Rule violation CKLD-2
Hello, I'm JH.
I met some waring.
"WARNING: [DRC 23-20] Rule violation (CKLD-2) Clock Net has IO Driver, not a Clock Buf, and/or non-Clock loads - Clock net cin_clk is directly driven by an IO rather than a Clock Buffer or may be an IO driveing a mix or Clock Buffer and no n-Clock loads. This connectivity shoul be reviewed and corrected as appropiate. Driver: U_CVCLKIN/O."
xdc file,  "define_attibute {p:CDIN[11:0]} syn_useioff 1"
RTL is,
IBUFG U_CVCLKIN (.I(CVCLKIN), .O(cin_clk));
always @(posedge cin_clk or negedge RSTN) begin
      if(!RSTN) begin
        data <= 12'h0;
    end
    else begin
         data <= CDIN;
    end
end
How to solve this problem?
syedz
@jeongho80.kim,
Can you open the schematic and check the connections of cin_clk? Check if the IBUFG is present at the clock.
Also check if the port is clock capable port.
--Syed
syedz
@jeongho80.kim,
Can you provide any update for this thread? Let us know if you have any more queries.
--Syed
sharathm@535
  • [DRC CKLD-2] Clock Net has IO Driver, not a Clock Buf, and/or non-Clock loads: Clock net clk_rst_gen/w_PCIe_refclk_bufg is directly driven by an IO rather than a Clock Buffer or may be an IO driving a mix of Clock Buffer and non-Clock loads. This connectivity should be reviewed and corrected as appropriate. Driver(s): clk_rst_gen/PCIe_refclk/O
Can someone help me with this warning?
Because of this my PCIe card is not getting detected in the system. Someone please help me with this.
sharathm@535
I'm using VIVADO 2017.2. I had instantiated a IBUFGDS but in the schematic it's showing IBUFDS.
IBUFGDS #(
.DIFF_TERM ("TRUE"), // Differential Termination
.IBUF_LOW_PWR ("TRUE"), // Low power="TRUE", Highest performance="FALSE"
.IOSTANDARD ("DEFAULT") // Specifies the I/O standard for this buffer
) PCIe_refclk (
.O (w_PCIe_refclk_bufg), // Clock buffer output
.I (i_PCIe_refclk_p), // Diff_p clock buffer input
.IB (i_PCIe_refclk_n) // Diff_n clock buffer input
ODDR #(
.DDR_CLK_EDGE ("OPPOSITE_EDGE"),
.INIT (1'b0),
.SRTYPE ("ASYNC")
) PCIe_refclk_p_0 (
.Q (o_PCIe_refclk_p[0]),
.C (w_PCIe_refclk_bufg),
.CE (1'b1),
.D1 (1'b1),
.D2 (1'b0),
.R (~board_reset_n),
.S (1'b0)
ODDR #(
.INIT (1'b0),
.SRTYPE ("ASYNC")
) PCIe_refclk_n_0 (
.Q (o_PCIe_refclk_n[0]),
.CE (1'b1),
.D1 (1'b0),
.D2 (1'b1),
.S (1'b0)
marcb
Hi @jeongho80.kim. The IBUFG will need to be replaced by an IBUF + BUFG instantiation. The IBUFG was targeted for older architectures. For newer architectures (7-Series, UltraScale/UltraScale+) the IBUFG will only result in an I/O buffer IBUF. This would result in the CKLD-2 DRC.
sharathm@535
After replacing IBUFGDS by an IBUF + BUFG instantiation, i'm getting the following Implementation error.
[Place 30-574] Poor placement for routing between an IO pin and BUFG.
[Place 30-99]Placer failed with error.'IO Clock Placer Failed'
marcb
Hi sharathm@535. Is the full message available to post as well as the full device name/part?  This will show what instances and physical sites are involved, and should show whether constraints are involved. The part will allow me to see the physical location of these relative to each other. The message should have a section such as below:
clk_IBUF_inst (IBUF.O) is locked to IOB_X0Y248
and BUFG_inst (BUFG.I) is locked to BUFGCTRL_X0Y31
