Newbie lujiaqi
[DRC 23-20] Rule violation (RTSTAT-2) Partially routed net - 152 net(s) are partially routed.
tool: vivado2015.2 FPGA: V7
Vivado Implementation fails to route my design completely. Below are some of the messages.
how to eliminate these errors?
The problem bus(es) and/or net(s) are
u0_eth_interface_top_PM/goo0[0].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/pcs_top_i/rx_pcs_i/rxreset_2,
u0_eth_interface_top_PM/goo0[1].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/pcs_top_i/rx_pcs_i/rxreset_2,
u0_eth_interface_top_PM/goo0[0].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/pcs_top_i/rx_pcs_i/rxreset_4,
u0_eth_interface_top_PM/goo0[1].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/pcs_top_i/rx_pcs_i/rxreset_4,
u0_eth_interface_top_PM/goo0[0].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/pcs_top_i/rx_pcs_i/rxreset_5,
u0_eth_interface_top_PM/goo0[1].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/pcs_top_i/rx_pcs_i/rxreset_5,
u0_eth_interface_top_PM/goo0[0].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/pcs_top_i/rx_pcs_i/rxreset_6,
u0_eth_interface_top_PM/goo0[1].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/pcs_top_i/rx_pcs_i/rxreset_6,
u0_eth_interface_top_PM/goo0[0].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/xgmii_txc_reg2[7:0],
u0_eth_interface_top_PM/goo0[1].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/xgmii_txc_reg2[7:0],
u0_eth_interface_top_PM/goo0[0].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/xgmii_txd_reg2[63:0],
u0_eth_interface_top_PM/goo0[1].u_xge_top/u_xge_mac_interface/u_xge_phy_core/U0/xge_phy_core_new_core/ten_gig_eth_pcs_pma_inst/G_IS_BASER.ten_gig_eth_pcs_pma_inst/BASER.ten_gig_eth_pcs_pma_inst/xgmii_txd_reg2[63:0].
Scholar watari
Re: [DRC 23-20] Rule violation (RTSTAT-2) Partially routed net - 152 net(s) are partially routed.
Hi @lujiaqi
I'm not sure. But the following AR (#65502) is helpful for you.
https://www.xilinx.com/support/answers/65502.html
Best regards,
Newbie lujiaqi
I'll try it ,thank you!
Hi @lujiaqi. Can the implementation log file be attached? I suspect congestion might be causing the routing failures, but a log would help to confirm. If this is the case, then the following answer record could help:
https://www.xilinx.com/support/answers/66314.html
