[DRC RTSTAT-13] Insufficient Routing
I have generated previously the bitstream and it took really long (~7hr), but it did, I only changed a clock in one block and now I've get this error:
"[DRC RTSTAT-13] Insufficient Routing: The design has 88.07 percent expected routable nets fully routed, which is less than the current RTSTAT threshold of 90 percent. Routed nets status (RTSTAT-*) checks will not be run. Please further implement the design to increase the percent of fully routed nets. The RTSTAT threshold can be changed with parameter drc.RTSTAT_minRoutedNetsPercent"
Looks like the router struggles to get everything routed and finally can't route all nets ?, is there anyway to fix or optimise this?
Re: [DRC RTSTAT-13] Insufficient Routing
Well, I managed to simplify the clock paths, and now it did work as I expected, it took long to implement, but not as long as before.
Scholar dpaul24
@joseer,
I have generated previously the bitstream and it took really long (~7hr), but it did, I.....
That should have have already"rung a bell" in your mind.
In many cases this occurs due to improperly constraining your design.
You should check that first.
How your RTL is written can be an issue, but it should be re-visited later.
FPGA enthusiast!
All PMs will be ignored
@dpaul24 thanks for your quick reply.
I know the time it ran is too much and I'm already checking constraints (for the moment they look ok)....but additionally  I wanted to check if there's any way to optimise and help the router to finish all.
Scholar dpaul24
@joseer,
That is not in my knowledge. May be some Xilinx personnel can provide you some exotic TCL tricks.
All I do is follow a proper RTL methodology and make sure that my constraints are correct.
FPGA enthusiast!
Hi @joseer ,
You said : "I managed to simplify the clock paths, " ,
could you instruct me about how to learn or how to do this " simplify the clock paths" ?
