Visitor onnerb
DRC Warning: RTSTAT-10 dbg_hub net(s) have no routable loads
Hi All,
I have instantiated a VIO and ILA custom debug core in my design and have successfully generated the bitstream and deployed it to the FPGA (Artix-7 xc7a35tcsg324-2L).
My design meets timing.
I am using Vivado (project mode) version v2017.4 (64-bit) on Windows 10 Pro
Everything works fine however I get the following DRC warning associated with the debug hub:
2. REPORT DETAILS
RTSTAT-10#1 Warning
No routable loads
21 net(s) have no routable loads. The problem bus(es) and/or net(s) are dbg_hub ......
I also get warnings in the VIO and ILA synthesis reports regarding "unconnected ports" which are clearly associated with the implementation DRC warning message.
Is this warning something that I should be concerned about?
Can someone please provide details on how I can resolve the warning message?
I have provided the following synthesis and drc reports:
1) ila.vds
The top level design report (Note: I named the project ila because this design is focused on evaluating the ILA debug core capability)
2) ila_drc_routed.rpt
The top level design DRC report
3) vio_0.vds
The VIO custom debug core synthesis report
4) ila_0.vds
The ILA custom debug core synthesis report
Hoping someone can assist me with this matter.
Re: DRC Warning: RTSTAT-10 dbg_hub net(s) have no routable loads
@onnerb
What is the output of report_route_status on complete design?
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug835-vivado-tcl-commands.pdf#page=1342
--Syed
Visitor onnerb
Hi Syedz,
I captured the report_route_status using several arguments (See attached and snippet below)
"ila_report_status_list_all_nets.rpt" lists the dbg_hug "Nets with No Loads"
Design Route Status
                                               :      # nets :
   # of logical nets.......................... :        4615 :
       # of nets not needing routing.......... :        1232 :
           # of internally routed nets........ :        1195 :
           # of nets with no loads............ :          37 :
       # of routable nets..................... :        3383 :
           # of fully routed nets............. :        3383 :
       # of nets with routing errors.......... :           0 :
- SNIP SNIP SNIP -
Nets with No Loads:
  Total  : 39
  Parents: 37
  Parent Net Names:
    ILA_INST/U0/ila_core_inst/u_ila_regs/U_XSDB_SLAVE/s_daddr_o[13]
    ILA_INST/U0/ila_core_inst/u_ila_regs/U_XSDB_SLAVE/s_daddr_o[14]
    ILA_INST/U0/ila_core_inst/u_ila_regs/U_XSDB_SLAVE/s_daddr_o[15]
    ILA_INST/U0/ila_core_inst/u_ila_regs/U_XSDB_SLAVE/s_daddr_o[16]
    ILA_INST/U0/sync_reg3
    ILA_INST/U0/trig_out_ack_reg
    dbg_hub/inst/BSCANID.u_xsdbm_id/CORE_XSDB.UUT_MASTER/U_ICON_INTERFACE/U_CMD1/ctl_reg_en_2[1]
    dbg_hub/inst/BSCANID.u_xsdbm_id/CORE_XSDB.UUT_MASTER/U_ICON_INTERFACE/U_CMD6_RD/U_RD_FIFO
    /SUBCORE_FIFO.xsdbm_v3_0_0_rdfifo_inst/inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gl0.rd/gr1.gr1_int.rfwft
    /aempty_fwft_i
 - SNIP SNIP SNIP -
Onnerb
@onnerb,
There is no routing error and all the nets seem to have routed successfully. The warning is on "No loads" on nets related to ILA.  Check the schematics and validate the connections.
https://forums.xilinx.com/t5/Design-Tools-Others/ILA-don-t-display-probes/m-p/820228
--Syed
Participant alexis_jp
@syeds @syedz That's quite a different problem. We get RTSTAT-10 warnings, that means the ILA/dbg_hub aren't routed and will never work.
That's a Xilinx problem, ila/dbg_hub are Xilinx IP cores. Why don't their signals have load?!
