Alir3za
DSP placement inside pblock
I am trying to have multiple pblocks each with a processing element that does multiplication. I use the following lines for each pblock inside my xdc file to create the pblock, resize it and add cells to it:
create_pblock y1x0
add_cells_to_pblock [get_pblocks y1x0] [get_cells -quiet [list {ys[1].xs[0].hoplite_inst} {ys[1].xs[0].pe_inst}]]
resize_pblock [get_pblocks y1x0] -add {SLICE_X16Y30:SLICE_X25Y39}
There are DSP blocks inside each pblock to use for doing the multiplication. However, sometimes Vivado uses a DSP block far away from the pblock for the multiplication while the DSPs inside the pblock are unused. This imposes heavy delays on my design. I was wondering if there is a way to make Vivado choose a DSP inside the pblock since the processing element is added to the pblock, without having to explicitly assign the multiplication to a specific DSP with a command like this:
set_property LOC DSP48_X0Y0 [get_cells {ys[1].xs[0].pe_inst/y_reg}];
I would like to avoid having to assign multiplication to specific DSPs as pblock sizes vary in my experiments.
I use Vivado 2020.1 and Alveo U280.
hongh
Hi, @Alir3za ,
In your pblock, only slice resource is included. There is no DSP resource in your pblock.
Please use resize_pblock command to add DSP resource:
Ex:resize_pblock pblock_XX -add {SLICE_X29Y295:SLICE_X32Y299 DSP48E2_X4Y118:DSP48E2_X4Y119}
