Design Summary/Reports are not updating
Hello all,
I am having trouble with my Xilinx tools.
I have the full design suite license through the Xilinx Alliance program.
I am using:
Project Navigator
Release Version: 14.5(nt)
Application Version : P.58f
I am implementing my design but after implementation has passed the Translation Report, Map report, Place and Route Report, Post-PAR Static Timing report will not update as well as the Design summary report.  The reports seem to be stuck on Synthesized.
See attachment below.
Does anyone know how to fix this?
Re: Design Summary/Reports are not updating
Try closing Design Summary window and open the design sumary from Project menu --> Design Summary/Reports
I tried that, the button on the toolbar and the processes tab.
Check this AR out.
http://www.xilinx.com/support/answers/39597.htm
Yes that appears to be what is happening...  I switch top Modules and synthesize and implement and the tools get lost and eventually the tools get lost.
Observer vjose
In the process tab you have an option to clean up the project files . Do the clean up of your project file . Then try out the synthesis . This will solve the issue .
With regards
Vintu
