Disable BUFGCE issue
Hello
I want to used vu440 FPGA device.
Have any constraint can be disable BUFGCE?
Re: Disable BUFGCE issue
@quincyq2003,
If you do not want the tool to infer any clock buffers (BUFGCE) then you can use clock_buffer_type set to None.
set_property CLOCK_BUFFER_TYPE NONE [get_nets ]
Check page 156 in below UG:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug912-vivado-properties.pdf#page=156
--Syed
@quincyq2003,
--Syed
