Does ISE have a function as the "virtual pin" in QUARTUS?
I used to use quartus, but now an ISE guy
in quartus, there's the so-called  "virtual pin",which is quite useful for IP core design, cuz we don't have to connect the pin of the core to the real pin on the board, but just treated it as a virtual one
and so
i'm wondering whether ISE also has such a kind of thing
thx for anyone help  n_n
Advisor
Advisor
Re: Does ISE have a function as the "virtual pin" in QUARTUS?
There is a Virtual IO (VIO) core that you can connect to the ICON core. Then you can access those virtual pins from the ChipScope.
 OutputLogic
If this is for timing analysis purpose, take a look at "TPSYNC" constraint in the constraint guide (http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/cgd.pdf).
Cheers,
Jim
Cheers,
Jim
not totally for timing consideration.
for example
if there exists an IP CORE with 1000 IOs, that far more than the real PINs the FPGA device has.
so if i'd simulate this CORE, it seems i can't place all of the IOs onto the PINs, so maybe i need
the so called "virtual pin", that just treat the IOs as virtual IO, and they would just place in the DEVICE and not in the PINs
