anupkini
[Drc 23-20] Rule violation (RTSTAT-2) Partially routed net
Hi All,
I am currently working a design for Virtex7-2000T, Vivado 2015.4, Ubuntu 16.04
During routing i get the following warning
Phase 9 Verifying routed nets
CRITICAL WARNING: [Route 35-162] 44750 signals failed to route due to routing congestion.
I changed the implementation strategy to SpreadLogic_medium, then to SpreadLogic_high
Still end up with a lot of signals failing to route.
Design Route Status
: # nets :
# of logical nets.......................... : 206396 :
# of nets not needing routing.......... : 44038 :
# of internally routed nets........ : 36039 :
# of nets with no loads............ : 7999 :
# of routable nets..................... : 162358 :
# of fully routed nets............. : 117608 :
# of nets with routing errors.......... : 44750 :
# of nets with resource conflicts.. : 44750 :
Kindly let me know how i can proceed with building my design.
Thanks & Regards,
Anup.
asitm
Hi @anupkini
Please refer AR66314 on Vivado Congestion and see if it helps.
https://www.xilinx.com/support/answers/66314.html
Asit
