ECO Flow
I was very happy to learn about ECO Flow, whereby one can re-assign the ports of an ILA to quickly regenerate a bitfile with different debug outputs.  I watched the Quick Take video and followed the steps there, opening a checkpoint (Viv2017.4, KC705 dev board) and changing the connections to the ILA.  But although the tool accepted my changes and the Incremental Route proceeded to completion, the new schematic did not show those ILA ports connected.  The old connections had been removed but the new ones were not made.
It's my first time using this new capability, so maybe I missed something, but it all flowed very smoothly, just like the video, with now warnings or errors.  Just didn't work.
Anybody have any ideas?
Rick
Re: ECO Flow
Hi, @rikraf ,
The below command can work in 2018.2:
open_checkpoint ./checkpoint_1.dcp
modify_debug_ports -probes [list {u_ila_1/probe1 0 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/m_axis_tready} {u_ila_1/probe1 1 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/m_axis_tvalid} {u_ila_1/probe3 0 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/axis_data_count[4]} {u_ila_1/probe3 1 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/axis_data_count[5]} {u_ila_1/probe3 3 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/axis_data_count[7]} {u_ila_1/probe3 4 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/axis_data_count[8]} {u_ila_1/probe1 2 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/s_axis_tready} {u_ila_1/probe1 3 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/s_axis_tvalid} {u_ila_1/probe3 2 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/axis_data_count[6]} {u_ila_1/probe3 5 base_mb_i/maroc_dc_0/inst/USR_LOGIC/PH_FIFO/axis_data_count[9]}]
Re: ECO Flow
Hi, @rikraf ,
You can refer the attached add_probe.tcl and show us what commands you are using.
You don't need to send out your own design and you can take the example design in Vivado to show what you are doing.
Re: ECO Flow
Attached is the set of commands generated by the GUI.  Having done that, the regenerated schematic shows all of the nets from probes 1 and 3 of ila_1 to be disconnected.  These were the ones that were previously connected, and which I tried to connect to new nets.
route_design seems to run without problem:
INFO: [DRC 23-27] Running DRC with 2 threads
INFO: [Vivado_Tcl 4-198] DRC finished with 0 Errors
INFO: [Vivado_Tcl 4-199] Please refer to the DRC report (report_drc) for more information.
Running DRC as a precondition to command route_design
INFO: [Common 17-83] Releasing license: Implementation
8 Infos, 0 Warnings, 0 Critical Warnings and 0 Errors encountered.
route_design completed successfully
Any help appreciated.
Re: ECO Flow
Hi, @rikraf ,
Generally, after executing "modify_debug_ports" command, it's no need to run route_design design again.
In your design, the new connection for probe is not established. There must be something wrong.
Could you provide your routed.dcp for further analysis? Are you using Vivado 2018.2?
Re: ECO Flow
Yes, here it is.  The QuickTake video seemed pretty clear on having to do an incremental route after replacing the probes
Re: ECO Flow
Hi, @rikraf ,
Re: ECO Flow
Hello Hong,
Thanks very much for the TCL script.  In fact I was able to use the "ECO flow" GUI successfully on another design, where I reassigned the debug probes. And, as you said, there was no need to run the "route design" process.  Maybe this was my mistake previously.  I'll use the tcl script next time and see how it goes.
Rick
