Visitor prigish
ERROR: [Common 17-161] Invalid option value '' specified for 'objects'
I am building a project using AWS F1 platform( xcvu9p-flgb2104-2-i).
I got the following error while compiling a project after the route design
ERROR: (Common 17-161) Invalid option value '' specified for 'objects'
The route design got completed successfully but the tool threw a error before the tarball creation step.
Any advice on this issue?
Prigish
Re: ERROR: [Common 17-161] Invalid option value '' specified for 'objects'
Hi @prigish.
The [runtcl-1] error would indicate a Tcl file is being accessed, and the command syntax is wrong. Is the Tcl file available that is run after the lock_routing command?
@prigish
Looks like incorrect constraint command is causing the error. Normally the tool will give the line number and details on the object which it is not able to find.
Did the design get routed successfully and met timing?
--Syed
Visitor prigish
Thanks Syed for the response.
Yes I am also expecting the tool to give the line number which is causing the problem but as you can see in the screenshot the tool doesn't give any information about the object which is causing trouble .
Yes the design got routed successfully but as told earlier this is an AWS F1 platform based project so after routing step ,there is a tarball creation step. The tool throws error before this step.
No the design has not met timing.
@prigish
Please post your query on AWS forums:
https://forums.aws.amazon.com/forum.jspa?forumID=243&start=0
--Syed
Visitor prigish
I have already posted it on AWS forum but didn't get a satisfying response which could solve my problem.
The link for my query on AWS forum :
https://forums.aws.amazon.com/thread.jspa?messageID=884229&#884229
Prigish
Hi @prigish.
Visitor prigish
Thanks Marc
The issue has been solved now.
@prigish
Thanks for the udpate. As the issue is resolved, Please close this open thread by marking the helpful post as "Accept as Solution"
If you have found the solution in amazon forums then share it here which will benefit other users and mark your post as "Accept as solution"
--Syed
