sasi8985
ERROR: [Common 17-162] Invalid option value specified for '-nets'
I am getting this error "ERROR: [Common 17-162] Invalid option value specified for '-nets'" pointing to my main constraints in a2o core.
can some one help me resolve this issue?
hongh
After removing the unconnected port of ILA, opt can continue to run.
Ex: delete_debug_port [get_debug_ports {u_ila_0/probe14 }]
hongh
sasi8985
Hi, i tried deleting the probe14(In the Ex you showed me) But still it says "Invalid option specified for "-nets". So, i Delted the lines from probe14 to probe 25. Now I am not getting any error.
What happens if i remove all probes from 14 to 25 in constraints files.
Thank you.
