ERROR: [Common 17-70] Application Exception: i_gnet->isConstant()
I am a beginner on synthesis and implementation and i am developing a university project using a Virtex 7 board.
I have got this error during the implementation phase with Vivado 2013.3:
[Vivado_Tcl 4-131] Power Optimization encountered an exception: ERROR: [Common 17-70] Application Exception: i_gnet->isConstant()
 As the message says, there is an error during the Power Optimization. Actually the Log file does not even say where it encounterd the error exactly, and i have no idea what is 'i_gnet'.
The implementation works as long as i remove all the optimization settings, but doing in this way i get a very bad timing result, especially due to a clock of 500Mhz received as input on the top module and spreaded all around my logic without using any MMCM.
Does anybody know how can i correct this error or at least other ways to recover the bad timing analysis?
Re: ERROR: [Common 17-70] Application Exception: i_gnet->isConstant()
Can you check this in vivado 2013.4?
Did you disable opt_design phase too? Rather than disabling the complete opt_design phase, you can just disable BRAM power optimization phase of opt_design. Write the below switches in more options field of opt_design.
 -retarget -propconst -sweep
Deepika.
Deepika.
Community Manager
Community Manager
There was a known CR for this power_opt. The number is
743771.
This is fixed in 2013.4. Please try in 2013.4 and update us.
Thanks for your reply.
Tomorrow, once back in my office, i will upgrade vivado and try again.
However, i disabled opt_design to avoid optimizations. I will also try yout trick
Antonio
Community Manager
Community Manager
Sure Please keep me posted. If it doesnt work in 2013.4, we have to investigate and file a CR if applicable.
Ok, i will upgrade it and try again.
Do you think i will have problems with my design suite license with the upgrade?
Antonio
Community Manager
Community Manager
Please check with the version limit of your license.
The following AR mentions the least duration of the version limits.
http://www.xilinx.com/support/answers/33770.htm
The trick proposed by vemulad worked.
Actually i still have to upgrade Vivado to the 2013.4 version. In the next few days, i will let you know when i will have done.
In the meanwhile thanks to everyone.
Antonio
Community Manager
Community Manager
Thanks for your update. Please keep us posted.
Community Manager
Community Manager
antonio.verlotta  Did you get a chance to run this in latest toosl ?
