ERROR: [Common 17-70] Application Exception
I'm getting the following error when I try to generate bitstream. I'm using Vivado 2020.1
ERROR: [Common 17-70] Application Exception: Unable to get BIT file from implementation run. Please ensure implementation has been run all the way through Bitstream generation. Aborting write_hw_platform..
Thank you for your time
Please review implementation report. There must be errors during implementation which didn't allow bitstream generation.
