ERROR: [EDIF 20-105] Parse error on or above line 1488019. EDIF file was not written properly by 'Synplify Premier'
There are 5 vivado ip edif inside my design.
1>for getting the best QoR,i try to load them with synplify2016.9.however,vivado reports the following error after loaded the final edif.
Design is defaulting to srcset: sources_1
Design is defaulting to constrset: constrs_1
Parsing EDIF File [./top.edf]
INFO: [Common 17-206] Exiting Vivado at Wed Mar 01 02:06:26 2017...
2>vivado works well if synplify reads blackbox file and vivado reads into 5 vivado ip edif separatly
why?
Re: ERROR: [EDIF 20-105] Parse error on or above line 1488019. EDIF file was not written properly by 'Synplify Premier'
Hi @m006
Check if this answer record helps: https://www.xilinx.com/support/answers/62587.html
Vinay
no,it is in the beginning stage of vivado loading edif netlist.My memory is enough.
The 5 edif netlist is from vivado dcp ip ( winzip decompress dcp).
Hi @m006
Can you try generating the EDIF from IP DCP using write_edif command and then use these newly generated EDIF files in synplify?
Deepika.
it is still same error with synplify add_vivado_ip command.
the add_vivado_ip is decomposed the following cmd.
open_checkpoint ./ipcores/ddr4_1/ddr4_1.dcp
write_verilog -force ./ipcores/ddr4_1/ddr4_1.v
write_verilog -mode pin_planning ./ipcores/ddr4_1/ddr4_1_wrapper.v
write_edif ./ipcores/ddr4_1/ddr4_1.edf
write_xdc -force ./ipcores/ddr4_1/ddr4_1.xdc
