Visitor kshitij_10
ERROR:Map:116 - The design is empty. No processing will be done
// hello i found this code (32 bit MIPS processor) on the internet but i am not able to map it to FPGA although it seems to work fine in simulation. can you please tell me what is the problem?
// I'm a beginner in this. Please help
`timescale 1ps / 100fs
// Company:
// Engineer:
// Create Date: 12:43:35 05/30/2019
// Design Name:
// Module Name: proc_32bit_alternate
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module MIPSpipeline(clk, reset, outk);
input clk, reset;
output [31:0] outk;
wire [31:0] PC, PCin;
wire [31:0] PC4,ID_PC4,EX_PC4;
wire [31:0] PCbne,PC4bne,PCj,PC4bnej,PCjr; // PC signals in MUX
wire [31:0] Instruction,ID_Instruction,EX_Instruction; // Output of Instruction Memory
wire [5:0] Opcode,Function; // Opcode, Function
// Extend
wire [15:0] imm16; // immediate in I type instruction
wire [31:0] Im16_Ext,EX_Im16_Ext;
wire [31:0] sign_ext_out,zero_ext_out;
// regfile
wire [4:0] rs,rt,rd,EX_rs,EX_rt,EX_rd,EX_WriteRegister,MEM_WriteRegister,WB_WriteRegister;
wire [31:0] WB_WriteData, ReadData1, ReadData2,ReadData1Out,ReadData2Out, EX_ReadData1, EX_ReadData2;
// ALU
wire [31:0] Bus_A_ALU,Bus_B_ALU,Bus_B_forwarded;
wire [31:0] EX_ALUResult,MEM_ALUResult,WB_ALUResult;
wire ZeroFlag, OverflowFlag, CarryFlag, NegativeFlag,notZeroFlag;
wire [31:0] WriteDataOfMem,MEM_ReadDataOfMem,WB_ReadDataOfMem;
//Control signals
wire RegDst,ALUSrc,MemtoReg,RegWrite,MemRead,MemWrite,Branch,Jump,SignZero,JRControl;
wire ID_RegDst,ID_ALUSrc,ID_MemtoReg,ID_RegWrite,ID_MemRead,ID_MemWrite,ID_Branch,ID_JRControl;
wire EX_RegDst,EX_ALUSrc,EX_MemtoReg,EX_RegWrite,EX_MemRead,EX_MemWrite,EX_Branch,EX_JRControl;
wire MEM_MemtoReg,MEM_RegWrite,MEM_MemRead,MEM_MemWrite;
wire WB_MemtoReg,WB_RegWrite;
wire [1:0] ALUOp,ID_ALUOp,EX_ALUOp;
wire [1:0] ALUControl;
wire bneControl,notbneControl;
wire JumpControl,JumpFlush;
wire [1:0] ForwardA,ForwardB;
//flush
wire IF_flush,IFID_flush,notIFID_flush,Stall_flush,flush;
//shift left
wire [31:0] shiftleft2_bne_out,shiftleft2_jump_out; // shift left output
// PC Write Enable, IF/ID Write Enable
wire PC_WriteEn,IFID_WriteEn;
assign outk= EX_ALUResult;
//====== PC register======
register PC_Reg(PC,PCin,PC_WriteEn,reset,clk);
Add Add1(PC4,PC,{29'b0,3'b100}); // PC4 = PC + 4
InstructionMem InstructionMem1(Instruction, PC);
// register IF/ID
register IFID_PC4(ID_PC4,PC4,IFID_WriteEn,reset,clk);
register IFID_Instruction(ID_Instruction,Instruction,IFID_WriteEn,reset,clk);
RegBit IF_flush_bit(IFID_flush,IF_flush, IFID_WriteEn,reset, clk);
//========= ID STAGE===========
assign Opcode = ID_Instruction[31:26];
assign Function = ID_Instruction[5:0];
assign rs = ID_Instruction[25:21];
assign rt = ID_Instruction[20:16];
assign rd = ID_Instruction[15:11];
assign imm16= ID_Instruction[15:0];
// Main Control
Control MainControl(
RegDst,
ALUSrc,
MemtoReg,
RegWrite,
MemRead,
MemWrite,
Branch,
ALUOp,
Jump,
SignZero,
Opcode
// Regfile
regfile Register_File(
ReadData1,
ReadData2,
WB_WriteData,
rs,
rt,
WB_WriteRegister,
WB_RegWrite,
reset,
clk);
// forward Read Data if Write and Read at the same time
WB_forward WB_forward_block(ReadData1Out,ReadData2Out,ReadData1,ReadData2,rs,rt,WB_WriteRegister,WB_WriteData,WB_RegWrite);
// Sign-extend
sign_extend sign_extend1(sign_ext_out,imm16);
// Zero-extend
zero_extend zero_extend1(zero_ext_out,imm16);
// immediate extend: sign or zero
mux2x32to32 muxSignZero( Im16_Ext,sign_ext_out,zero_ext_out, SignZero);
JRControl_Block JRControl_Block1( JRControl, ALUOp, Function);
Discard_Instr Discard_Instr_Block(ID_flush,IF_flush,JumpControl,bneControl,EX_JRControl);
or #(50) OR_flush(flush,ID_flush,IFID_flush,Stall_flush);
flush_block flush_block1(ID_RegDst,ID_ALUSrc,ID_MemtoReg,ID_RegWrite,ID_MemRead,ID_MemWrite,ID_Branch,ID_ALUOp,
ID_JRControl,flush,RegDst,ALUSrc,MemtoReg,RegWrite,MemRead,MemWrite,Branch,ALUOp,JRControl);
//==========EX STAGE=========================
// thanh ghi ID/EX
register IDEX_PC4(EX_PC4,ID_PC4,1'b1,reset,clk);
register IDEX_ReadData1(EX_ReadData1,ReadData1Out,1'b1,reset,clk);
register IDEX_ReadData2(EX_ReadData2,ReadData2Out,1'b1,reset,clk);
register IDEX_Im16_Ext(EX_Im16_Ext,Im16_Ext,1'b1,reset,clk);
register IDEX_rs_rt_rd(EX_Instruction[31:0],ID_Instruction,1'b1,reset,clk);
assign EX_rs = EX_Instruction[25:21];
assign EX_rt = EX_Instruction[20:16];
assign EX_rd = EX_Instruction[15:11];
// 9 control signals via ID/EX
RegBit IDEX_RegDst(EX_RegDst, ID_RegDst, 1'b1,reset, clk);
RegBit IDEX_ALUSrc(EX_ALUSrc, ID_ALUSrc, 1'b1,reset, clk);
RegBit IDEX_MemtoReg(EX_MemtoReg, ID_MemtoReg, 1'b1,reset, clk);
RegBit IDEX_RegWrite(EX_RegWrite, ID_RegWrite, 1'b1,reset, clk);
RegBit IDEX_MemRead(EX_MemRead, ID_MemRead, 1'b1,reset, clk);
RegBit IDEX_MemWrite(EX_MemWrite, ID_MemWrite, 1'b1,reset, clk);
RegBit IDEX_Branch(EX_Branch, ID_Branch, 1'b1,reset, clk);
RegBit IDEX_JRControl(EX_JRControl, ID_JRControl, 1'b1,reset, clk);
RegBit IDEX_ALUOp1(EX_ALUOp[1], ID_ALUOp[1], 1'b1,reset, clk);
RegBit IDEX_ALUOp0(EX_ALUOp[0], ID_ALUOp[0], 1'b1,reset, clk);
// Forwarding unit
ForwardingUnit Forwarding_Block(ForwardA,ForwardB,MEM_RegWrite,WB_RegWrite,MEM_WriteRegister,WB_WriteRegister,EX_rs,EX_rt);
// mux 3 x32 to 32 to choose source of ALU (forwarding)
mux3x32to32 mux3A(Bus_A_ALU,EX_ReadData1,MEM_ALUResult,WB_WriteData,ForwardA);
mux3x32to32 mux3B(Bus_B_forwarded,EX_ReadData2,MEM_ALUResult,WB_WriteData,ForwardB);
// mux 2x32 to 32 to select source Bus B of ALU
mux2x32to32 muxALUSrc( Bus_B_ALU,Bus_B_forwarded,EX_Im16_Ext, EX_ALUSrc);
// ALU Control
ALUControl_Block ALUControl_Block1( ALUControl, EX_ALUOp, EX_Im16_Ext[5:0]);
// EX_Im16_Ext[5:0] is function
// ALU
alu alu_block(EX_ALUResult, CarryFlag, ZeroFlag, OverflowFlag, NegativeFlag, Bus_A_ALU, Bus_B_ALU, ALUControl);
// mux 2x5 to 5 choose shift register is Rd or Rt
mux2x5to5 muxRegDst( EX_WriteRegister,EX_rt,EX_rd, EX_RegDst);
//==============MEM STAGE=================
// register EX/MEM
register EXMEM_ALUResult(MEM_ALUResult,EX_ALUResult,1'b1,reset,clk);
register EXMEM_WriteDataOfMem(WriteDataOfMem, Bus_B_forwarded,1'b1,reset,clk);
RegBit EXMEM_MemtoReg(MEM_MemtoReg, EX_MemtoReg, 1'b1,reset, clk);
RegBit EXMEM_RegWrite(MEM_RegWrite, EX_RegWrite, 1'b1,reset, clk);
RegBit EXMEM_MemRead(MEM_MemRead, EX_MemRead, 1'b1,reset, clk);
RegBit EXMEM_MemWrite(MEM_MemWrite, EX_MemWrite, 1'b1,reset, clk);
RegBit EXMEM_WriteRegister4(MEM_WriteRegister[4], EX_WriteRegister[4], 1'b1,reset, clk);
RegBit EXMEM_WriteRegister3(MEM_WriteRegister[3], EX_WriteRegister[3], 1'b1,reset, clk);
RegBit EXMEM_WriteRegister2(MEM_WriteRegister[2], EX_WriteRegister[2], 1'b1,reset, clk);
RegBit EXMEM_WriteRegister1(MEM_WriteRegister[1], EX_WriteRegister[1], 1'b1,reset, clk);
RegBit EXMEM_WriteRegister0(MEM_WriteRegister[0], EX_WriteRegister[0], 1'b1,reset, clk);
// Data Memory
dataMem dataMem1(MEM_ReadDataOfMem, //data
MEM_ALUResult, //address
WriteDataOfMem, //writedata
MEM_MemWrite, //writeenable
MEM_MemRead,
clk);
//==========WB STAGE====================
// register MEM/WB
register MEMWB_ReadDataOfMem(WB_ReadDataOfMem,MEM_ReadDataOfMem,1'b1,reset,clk);
register MEMWB_ALUResult(WB_ALUResult,MEM_ALUResult,1'b1,reset,clk);
RegBit MEMWB_WriteRegister4(WB_WriteRegister[4], MEM_WriteRegister[4], 1'b1,reset, clk);
RegBit MEMWB_WriteRegister3(WB_WriteRegister[3], MEM_WriteRegister[3], 1'b1,reset, clk);
RegBit MEMWB_WriteRegister2(WB_WriteRegister[2], MEM_WriteRegister[2], 1'b1,reset, clk);
RegBit MEMWB_WriteRegister1(WB_WriteRegister[1], MEM_WriteRegister[1], 1'b1,reset, clk);
RegBit MEMWB_WriteRegister0(WB_WriteRegister[0], MEM_WriteRegister[0], 1'b1,reset, clk);
RegBit MEMWB_MemtoReg(WB_MemtoReg, MEM_MemtoReg, 1'b1,reset, clk);
RegBit MEMWB_RegWrite(WB_RegWrite, MEM_RegWrite, 1'b1,reset, clk);
// Select Data to WriteData for regfile
mux2x32to32 muxMemtoReg( WB_WriteData, WB_ALUResult, WB_ReadDataOfMem,WB_MemtoReg);
//Stalling
StallControl StallControl_block(PC_WriteEn,IFID_WriteEn,Stall_flush,EX_MemRead,EX_rt,rs,rt,Opcode);
//Jump,bne, JRs
// bne: Branch if not equal
shift_left_2 shiftleft2_bne(shiftleft2_bne_out, EX_Im16_Ext);
Add Add_bne(PCbne,EX_PC4,shiftleft2_bne_out);
not #(50) notZero(notZeroFlag,ZeroFlag);
and #(50) andbneControl(bneControl,EX_Branch,notZeroFlag);
mux2x32to32 muxbneControl( PC4bne,PC4, PCbne, bneControl);
// jump
shift_left_2 shiftleft2_jump(shiftleft2_jump_out, {6'b0,ID_Instruction[25:0]});
assign PCj = {ID_PC4[31:28],shiftleft2_jump_out[27:0]};
not #(50) notIFIDFlush(notIFID_flush,IFID_flush);
and #(50) andJumpFlush(JumpFlush,Jump,notIFID_flush);
not #(50) notbne(notbneControl,bneControl);
and #(50) andJumpBNE(JumpControl,JumpFlush,notbneControl);
mux2x32to32 muxJump( PC4bnej,PC4bne, PCj, JumpControl);
// JR: Jump Register
assign PCjr = Bus_A_ALU;
mux2x32to32 muxJR( PCin,PC4bnej, PCjr, EX_JRControl);
endmodule
module InstructionMem(instruction, address);
input [31:0] address;
output [31:0] instruction;
reg [31:0]instrmem[1023:0];
reg [31:0] temp;
buf #1000 buf0(instruction[0],temp[0]),
buf1(instruction[1],temp[1]),
buf2(instruction[2],temp[2]),
buf3(instruction[3],temp[3]),
buf4(instruction[4],temp[4]),
buf5(instruction[5],temp[5]),
buf6(instruction[6],temp[6]),
buf7(instruction[7],temp[7]),
buf8(instruction[8],temp[8]),
buf9(instruction[9],temp[9]),
buf10(instruction[10],temp[10]),
buf11(instruction[11],temp[11]),
buf12(instruction[12],temp[12]),
buf13(instruction[13],temp[13]),
buf14(instruction[14],temp[14]),
buf15(instruction[15],temp[15]),
buf16(instruction[16],temp[16]),
buf17(instruction[17],temp[17]),
buf18(instruction[18],temp[18]),
buf19(instruction[19],temp[19]),
buf20(instruction[20],temp[20]),
buf21(instruction[21],temp[21]),
buf22(instruction[22],temp[22]),
buf23(instruction[23],temp[23]),
buf24(instruction[24],temp[24]),
buf25(instruction[25],temp[25]),
buf26(instruction[26],temp[26]),
buf27(instruction[27],temp[27]),
buf28(instruction[28],temp[28]),
buf29(instruction[29],temp[29]),
buf30(instruction[30],temp[30]),
buf31(instruction[31],temp[31]);
always @(address)
begin
temp=instrmem[address/4];
end
initial
begin
$readmemb("instr.txt", instrmem);
end
endmodule
module instrmemstimulous();
reg [31:0] addr;
wire [31:0] instr;
InstructionMem instructionmemory(instr, addr);
initial
begin
$monitor("Mem Address=%h instruction=%b",addr,instr);
addr=32'd0;
#10000 addr=32'd4;
#10000 addr=32'd8;
#10000 addr=32'd12;
#10000 addr=32'd16;
#10000 addr=32'd20;
#10000 addr=32'd24;
#10000 addr=32'd28;
#10000;
$finish;
end
endmodule
module Add(S,A,B);
output [31:0] S;
input [31:0] A,B;
wire [31:0] C;
adder1bit adder1bit0(S[0],C[0],A[0],B[0],1'b0);
adder1bit adder1bit1(S[1],C[1],A[1],B[1],C[0]);
adder1bit adder1bit2(S[2],C[2],A[2],B[2],C[1]);
adder1bit adder1bit3(S[3],C[3],A[3],B[3],C[2]);
adder1bit adder1bit4(S[4],C[4],A[4],B[4],C[3]);
adder1bit adder1bit5(S[5],C[5],A[5],B[5],C[4]);
adder1bit adder1bit6(S[6],C[6],A[6],B[6],C[5]);
adder1bit adder1bit7(S[7],C[7],A[7],B[7],C[6]);
adder1bit adder1bit8(S[8],C[8],A[8],B[8],C[7]);
adder1bit adder1bit9(S[9],C[9],A[9],B[9],C[8]);
adder1bit adder1bit10(S[10],C[10],A[10],B[10],C[9]);
adder1bit adder1bit11(S[11],C[11],A[11],B[11],C[10]);
adder1bit adder1bit12(S[12],C[12],A[12],B[12],C[11]);
adder1bit adder1bit13(S[13],C[13],A[13],B[13],C[12]);
adder1bit adder1bit14(S[14],C[14],A[14],B[14],C[13]);
adder1bit adder1bit15(S[15],C[15],A[15],B[15],C[14]);
adder1bit adder1bit16(S[16],C[16],A[16],B[16],C[15]);
adder1bit adder1bit17(S[17],C[17],A[17],B[17],C[16]);
adder1bit adder1bit18(S[18],C[18],A[18],B[18],C[17]);
adder1bit adder1bit19(S[19],C[19],A[19],B[19],C[18]);
adder1bit adder1bit20(S[20],C[20],A[20],B[20],C[19]);
adder1bit adder1bit21(S[21],C[21],A[21],B[21],C[20]);
adder1bit adder1bit22(S[22],C[22],A[22],B[22],C[21]);
adder1bit adder1bit23(S[23],C[23],A[23],B[23],C[22]);
adder1bit adder1bit24(S[24],C[24],A[24],B[24],C[23]);
adder1bit adder1bit25(S[25],C[25],A[25],B[25],C[24]);
adder1bit adder1bit26(S[26],C[26],A[26],B[26],C[25]);
adder1bit adder1bit27(S[27],C[27],A[27],B[27],C[26]);
adder1bit adder1bit28(S[28],C[28],A[28],B[28],C[27]);
adder1bit adder1bit29(S[29],C[29],A[29],B[29],C[28]);
adder1bit adder1bit30(S[30],C[30],A[30],B[30],C[29]);
adder1bit adder1bit31(S[31],C[31],A[31],B[31],C[30]);
endmodule
//`timescale 1 ps / 100 fs
module adder1bit(sum,cout,a,b,cin);
input a,b,cin;
output cout,sum;
// sum = a xor b xor cin
xor #(50) (sum,a,b,cin);
// carry out = a.b + cin.(a+b)
and #(50) and1(c1,a,b);
or #(50) or1(c2,a,b);
and #(50) and2(c3,c2,cin);
or #(50) or2(cout,c1,c3);
endmodule
module regfile(
ReadData1,
ReadData2,
WriteData,
ReadRegister1,
ReadRegister2,
WriteRegister,
RegWrite,
reset,
clk);
input [4:0]ReadRegister1,ReadRegister2,WriteRegister;
input [31:0] WriteData;
input RegWrite,reset, clk;
output [31:0] ReadData1, ReadData2;
wire [31:0] WriteEn;
wire [31:0] RegArray [0:31];
integer i;
//----Decoder Block
decoder Decoder1( WriteEn,RegWrite,WriteRegister);
register reg0 (RegArray[0],32'b0,1'b1,1'b0, clk);
register reg1 (RegArray[1],WriteData,WriteEn[1],reset,clk);
register reg2 (RegArray[2],WriteData,WriteEn[2],reset,clk);
register reg3 (RegArray[3],WriteData,WriteEn[3],reset,clk);
register reg4 (RegArray[4],WriteData,WriteEn[4],reset,clk);
register reg5 (RegArray[5],WriteData,WriteEn[5],reset,clk);
register reg6 (RegArray[6],WriteData,WriteEn[6],reset,clk);
register reg7 (RegArray[7],WriteData,WriteEn[7],reset,clk);
register reg8 (RegArray[8],WriteData,WriteEn[8],reset,clk);
register reg9 (RegArray[9],WriteData,WriteEn[9],reset,clk);
register reg10 (RegArray[10],WriteData,WriteEn[10],reset,clk);
register reg11 (RegArray[11],WriteData,WriteEn[11],reset,clk);
register reg12 (RegArray[12],WriteData,WriteEn[12],reset,clk);
register reg13 (RegArray[13],WriteData,WriteEn[13],reset,clk);
register reg14 (RegArray[14],WriteData,WriteEn[14],reset,clk);
register reg15 (RegArray[15],WriteData,WriteEn[15],reset,clk);
register reg16 (RegArray[16],WriteData,WriteEn[16],reset,clk);
register reg17 (RegArray[17],WriteData,WriteEn[17],reset,clk);
register reg18 (RegArray[18],WriteData,WriteEn[18],reset,clk);
register reg19 (RegArray[19],WriteData,WriteEn[19],reset,clk);
register reg20 (RegArray[20],WriteData,WriteEn[20],reset,clk);
register reg21 (RegArray[21],WriteData,WriteEn[21],reset,clk);
register reg22 (RegArray[22],WriteData,WriteEn[22],reset,clk);
register reg23 (RegArray[23],WriteData,WriteEn[23],reset,clk);
register reg24 (RegArray[24],WriteData,WriteEn[24],reset,clk);
register reg25 (RegArray[25],WriteData,WriteEn[25],reset,clk);
register reg26 (RegArray[26],WriteData,WriteEn[26],reset,clk);
register reg27 (RegArray[27],WriteData,WriteEn[27],reset,clk);
register reg28 (RegArray[28],WriteData,WriteEn[28],reset,clk);
register reg29 (RegArray[29],WriteData,WriteEn[29],reset,clk);
register reg30 (RegArray[30],WriteData,WriteEn[30],reset,clk);
register reg31 (RegArray[31],WriteData,WriteEn[31],reset,clk);
//----32x32to32 Multiplexor1 Block----
mux32x32to32 Mux1(ReadData1,RegArray[0], RegArray[1],RegArray[2], RegArray[3],RegArray[4],RegArray[5],RegArray[6],RegArray[7],
RegArray[8],RegArray[9],RegArray[10],RegArray[11],RegArray[12],RegArray[13],RegArray[14],RegArray[15],RegArray[16],RegArray[17],
RegArray[18], RegArray[19],RegArray[20],RegArray[21],RegArray[22],RegArray[23],RegArray[24],RegArray[25],RegArray[26],
RegArray[27], RegArray[28], RegArray[29],RegArray[30],RegArray[31], ReadRegister1
//----32x32to32 Multiplexor2 Block----
mux32x32to32 Mux2(ReadData2,RegArray[0], RegArray[1],RegArray[2], RegArray[3],RegArray[4],RegArray[5],RegArray[6],RegArray[7],
RegArray[27], RegArray[28], RegArray[29],RegArray[30],RegArray[31], ReadRegister2
endmodule
//------------DFF-------------------
module D_FF (q, d, reset, clk);
output q;
input d, reset, clk;
reg q; // Indicate that q is stateholding
always @(posedge clk or posedge reset)
if (reset)
q = 0; // On reset, set to 0
else
q = d; // Otherwise out = d
endmodule
// 1 bit register
module RegBit(BitOut, BitData, WriteEn,reset, clk);
output BitOut; // 1 bit of register
input BitData, WriteEn;
input reset,clk;
wire d,f1, f2; // input of D Flip-Flop
wire reset;
//assign reset=0;
and #(50) U1(f1, BitOut, (~WriteEn));
and #(50) U2(f2, BitData, WriteEn);
or #(50) U3(d, f1, f2);
D_FF DFF0(BitOut, d, reset, clk);
endmodule
//32 bit register
module register(RegOut,RegIn,WriteEn,reset,clk);
output [31:0] RegOut;
input [31:0] RegIn;
input WriteEn,reset, clk;
RegBit bit31(RegOut[31],RegIn[31],WriteEn,reset,clk);
RegBit bit30(RegOut[30],RegIn[30],WriteEn,reset,clk);
RegBit bit29(RegOut[29],RegIn[29],WriteEn,reset,clk);
RegBit bit28(RegOut[28],RegIn[28],WriteEn,reset,clk);
RegBit bit27(RegOut[27],RegIn[27],WriteEn,reset,clk);
RegBit bit26(RegOut[26],RegIn[26],WriteEn,reset,clk);
RegBit bit25(RegOut[25],RegIn[25],WriteEn,reset,clk);
RegBit bit24(RegOut[24],RegIn[24],WriteEn,reset,clk);
RegBit bit23(RegOut[23],RegIn[23],WriteEn,reset,clk);
RegBit bit22(RegOut[22],RegIn[22],WriteEn,reset,clk);
RegBit bit21(RegOut[21],RegIn[21],WriteEn,reset,clk);
RegBit bit20(RegOut[20],RegIn[20],WriteEn,reset,clk);
RegBit bit19(RegOut[19],RegIn[19],WriteEn,reset,clk);
RegBit bit18(RegOut[18],RegIn[18],WriteEn,reset,clk);
RegBit bit17(RegOut[17],RegIn[17],WriteEn,reset,clk);
RegBit bit16(RegOut[16],RegIn[16],WriteEn,reset,clk);
RegBit bit15(RegOut[15],RegIn[15],WriteEn,reset,clk);
RegBit bit14(RegOut[14],RegIn[14],WriteEn,reset,clk);
RegBit bit13(RegOut[13],RegIn[13],WriteEn,reset,clk);
RegBit bit12(RegOut[12],RegIn[12],WriteEn,reset,clk);
RegBit bit11(RegOut[11],RegIn[11],WriteEn,reset,clk);
RegBit bit10(RegOut[10],RegIn[10],WriteEn,reset,clk);
RegBit bit9 (RegOut[9], RegIn[9], WriteEn,reset,clk);
RegBit bit8 (RegOut[8], RegIn[8], WriteEn,reset,clk);
RegBit bit7 (RegOut[7], RegIn[7], WriteEn,reset,clk);
RegBit bit6 (RegOut[6], RegIn[6], WriteEn,reset,clk);
RegBit bit5 (RegOut[5], RegIn[5], WriteEn,reset,clk);
RegBit bit4 (RegOut[4], RegIn[4], WriteEn,reset,clk);
RegBit bit3 (RegOut[3], RegIn[3], WriteEn,reset,clk);
RegBit bit2 (RegOut[2], RegIn[2], WriteEn,reset,clk);
RegBit bit1 (RegOut[1], RegIn[1], WriteEn,reset,clk);
RegBit bit0 (RegOut[0], RegIn[0], WriteEn,reset,clk);
endmodule
// Decoder
module decoder(WriteEn,RegWrite, WriteRegister);
input RegWrite;
input [4:0] WriteRegister;
output [31:0] WriteEn;
wire [31:0] OE; // Output Enable
dec5to32 dec(OE,WriteRegister);
assign WriteEn[0]=0;
and #(50) gate1(WriteEn[1],OE[1],RegWrite);
and #(50) gate2(WriteEn[2],OE[2],RegWrite);
and #(50) gate3(WriteEn[3],OE[3],RegWrite);
and #(50) gate4(WriteEn[4],OE[4],RegWrite);
and #(50) gate5(WriteEn[5],OE[5],RegWrite);
and #(50) gate6(WriteEn[6],OE[6],RegWrite);
and #(50) gate7(WriteEn[7],OE[7],RegWrite);
and #(50) gate8(WriteEn[8],OE[8],RegWrite);
and #(50) gate9(WriteEn[9],OE[9],RegWrite);
and #(50) gate10(WriteEn[10],OE[10],RegWrite);
and #(50) gate11(WriteEn[11],OE[11],RegWrite);
and #(50) gate12(WriteEn[12],OE[12],RegWrite);
and #(50) gate13(WriteEn[13],OE[13],RegWrite);
and #(50) gate14(WriteEn[14],OE[14],RegWrite);
and #(50) gate15(WriteEn[15],OE[15],RegWrite);
and #(50) gate16(WriteEn[16],OE[16],RegWrite);
and #(50) gate17(WriteEn[17],OE[17],RegWrite);
and #(50) gate18(WriteEn[18],OE[18],RegWrite);
and #(50) gate19(WriteEn[19],OE[19],RegWrite);
and #(50) gate20(WriteEn[20],OE[20],RegWrite);
and #(50) gate21(WriteEn[21],OE[21],RegWrite);
and #(50) gate22(WriteEn[22],OE[22],RegWrite);
and #(50) gate23(WriteEn[23],OE[23],RegWrite);
and #(50) gate24(WriteEn[24],OE[24],RegWrite);
and #(50) gate25(WriteEn[25],OE[25],RegWrite);
and #(50) gate26(WriteEn[26],OE[26],RegWrite);
and #(50) gate27(WriteEn[27],OE[27],RegWrite);
and #(50) gate28(WriteEn[28],OE[28],RegWrite);
and #(50) gate29(WriteEn[29],OE[29],RegWrite);
and #(50) gate30(WriteEn[30],OE[30],RegWrite);
and #(50) gate31(WriteEn[31],OE[31],RegWrite);
endmodule
module andmore(g,a,b,c,d,e);
output g;
input a,b,c,d,e;
and #(50) and1(f1,a,b,c,d),
and2(g,f1,e);
endmodule
module dec5to32(Out,Adr);
input [4:0] Adr; // Adr=Address of register
output [31:0] Out;
not #(50) Inv4(Nota, Adr[4]);
not #(50) Inv3(Notb, Adr[3]);
not #(50) Inv2(Notc, Adr[2]);
not #(50) Inv1(Notd, Adr[1]);
not #(50) Inv0(Note, Adr[0]);
andmore a0(Out[0], Nota,Notb,Notc,Notd,Note); // 00000
andmore a1(Out[1], Nota,Notb,Notc,Notd,Adr[0]); // 00001
andmore a2(Out[2], Nota,Notb,Notc,Adr[1],Note); //00010
andmore a3(Out[3], Nota,Notb,Notc,Adr[1],Adr[0]);
andmore a4(Out[4], Nota,Notb,Adr[2],Notd,Note);
andmore a5(Out[5], Nota,Notb,Adr[2],Notd,Adr[0]);
andmore a6(Out[6], Nota,Notb,Adr[2],Adr[1],Note);
andmore a7(Out[7], Nota,Notb,Adr[2],Adr[1],Adr[0]);
andmore a8(Out[8], Nota,Adr[3],Notc,Notd,Note);
andmore a9(Out[9], Nota,Adr[3],Notc,Notd,Adr[0]);
andmore a10(Out[10], Nota,Adr[3],Notc,Adr[1],Note);
andmore a11(Out[11], Nota,Adr[3],Notc,Adr[1],Adr[0]);
andmore a12(Out[12], Nota,Adr[3],Adr[2],Notd,Note);
andmore a13(Out[13], Nota,Adr[3],Adr[2],Notd,Adr[0]);
andmore a14(Out[14], Nota,Adr[3],Adr[2],Adr[1],Note);
andmore a15(Out[15], Nota,Adr[3],Adr[2],Adr[1],Adr[0]);
andmore a16(Out[16], Adr[4],Notb,Notc,Notd,Note);
andmore a17(Out[17], Adr[4],Notb,Notc,Notd,Adr[0]);
andmore a18(Out[18], Adr[4],Notb,Notc,Adr[1],Note);
andmore a19(Out[19], Adr[4],Notb,Notc,Adr[1],Adr[0]);
andmore a20(Out[20], Adr[4],Notb,Adr[2],Notd,Note);
andmore a21(Out[21], Adr[4],Notb,Adr[2],Notd,Adr[0]);
andmore a22(Out[22], Adr[4],Notb,Adr[2],Adr[1],Note);
andmore a23(Out[23], Adr[4],Notb,Adr[2],Adr[1],Adr[0]);
andmore a24(Out[24], Adr[4],Adr[3],Notc,Notd,Note);
andmore a25(Out[25], Adr[4],Adr[3],Notc,Notd,Adr[0]);
andmore a26(Out[26], Adr[4],Adr[3],Notc,Adr[1],Note);
andmore a27(Out[27], Adr[4],Adr[3],Notc,Adr[1],Adr[0]);
andmore a28(Out[28], Adr[4],Adr[3],Adr[2],Notd,Note);
andmore a29(Out[29], Adr[4],Adr[3],Adr[2],Notd,Adr[0]);
andmore a30(Out[30], Adr[4],Adr[3],Adr[2],Adr[1],Note);
andmore a31(Out[31], Adr[4],Adr[3],Adr[2],Adr[1],Adr[0]); // 11111
endmodule
//------------module multiplexor 32 to 1----------------
module mux32to1(Out, In , Select);
output Out;
input [31:0] In;
input [4:0] Select;
wire [31:0] OE,f; // OE = Output Enable
dec5to32 dec1(OE,Select);
and #(50) g_0(f[0],OE[0],In[0]);
and #(50) g_1(f[1],OE[1],In[1]);
and #(50) g_2(f[2],OE[2],In[2]);
and #(50) g_3(f[3],OE[3],In[3]);
and #(50) g_4(f[4],OE[4],In[4]);
and #(50) g_5(f[5],OE[5],In[5]);
and #(50) g_6(f[6],OE[6],In[6]);
and #(50) g_7(f[7],OE[7],In[7]);
and #(50) g_8(f[8],OE[8],In[8]);
and #(50) g_9(f[9],OE[9],In[9]);
and #(50) g_10(f[10],OE[10],In[10]);
and #(50) g_11(f[11],OE[11],In[11]);
and #(50) g_12(f[12],OE[12],In[12]);
and #(50) g_13(f[13],OE[13],In[13]);
and #(50) g_14(f[14],OE[14],In[14]);
and #(50) g_15(f[15],OE[15],In[15]);
and #(50) g_16(f[16],OE[16],In[16]);
and #(50) g_17(f[17],OE[17],In[17]);
and #(50) g_18(f[18],OE[18],In[18]);
and #(50) g_19(f[19],OE[19],In[19]);
and #(50) g_20(f[20],OE[20],In[20]);
and #(50) g_21(f[21],OE[21],In[21]);
and #(50) g_22(f[22],OE[22],In[22]);
and #(50) g_23(f[23],OE[23],In[23]);
and #(50) g_24(f[24],OE[24],In[24]);
and #(50) g_25(f[25],OE[25],In[25]);
and #(50) g_26(f[26],OE[26],In[26]);
and #(50) g_27(f[27],OE[27],In[27]);
and #(50) g_28(f[28],OE[28],In[28]);
and #(50) g_29(f[29],OE[29],In[29]);
and #(50) g_30(f[30],OE[30],In[30]);
and #(50) g_31(f[31],OE[31],In[31]);
or #(50) gate3(g3,f[0],f[1],f[2],f[3]);
or #(50) gate4(g4,f[4],f[5],f[6],f[7]);
or #(50) gate5(g5,f[8],f[9],f[10],f[11]);
or #(50) gate6(g6,f[12],f[13],f[14],f[15]);
or #(50) gate7(g7,f[16],f[17],f[18],f[19]);
or #(50) gate8(g8,f[20],f[21],f[22],f[23]);
or #(50) gate9(g9,f[24],f[25],f[26],f[27]);
or #(50) gate10(g10,f[28],f[29],f[30],f[31]);
or #(50) gate11(g11,g3,g4,g5,g6);
or #(50) gate12(g12,g7,g8,g9,10);
or #(50) gate(Out,g11,g12);
endmodule
module mux32x32to32(ReadData,In0, In1,In2,In3,In4,In5,In6,In7,In8,In9,In10,In11,In12,In13,In14,In15,In16,In17,In18,In19,In20,In21,In22,In23, In24,In25,In26,In27,In28,In29,In30,In31,ReadRegister);
input [31:0] In0, In1,In2,In3,In4,In5,In6,In7,In8,In9,In10,In11,In12,In13,In14,In15,In16,In17,In18,In19,In20,In21,In22,In23,In24,In25,In26,In27,In28,In29,In30,In31;
input [4:0] ReadRegister;
output [31:0] ReadData;
reg [31:0] ArrayReg [0:31];
integer j;
always @(*)
begin
for (j=0;j<=31;j=j+1)
ArrayReg[j] = {In31[j], In30[j],In29[j],In28[j],In27[j],In26[j],In25[j],In24[j],In23[j],In22[j],In21[j],
In20[j],In19[j],In18[j],In17[j],In16[j],In15[j],In14[j],In13[j],In12[j],In11[j],
In10[j],In9[j],In8[j],In7[j],In6[j],In5[j],In4[j],In3[j],In2[j],In1[j],In0[j]};
end
mux32to1 mux0(ReadData[0],ArrayReg[0],ReadRegister);
mux32to1 mux1(ReadData[1],ArrayReg[1],ReadRegister);
mux32to1 mux2(ReadData[2],ArrayReg[2],ReadRegister);
mux32to1 mux3(ReadData[3],ArrayReg[3],ReadRegister);
mux32to1 mux4(ReadData[4],ArrayReg[4],ReadRegister);
mux32to1 mux5(ReadData[5],ArrayReg[5],ReadRegister);
mux32to1 mux6(ReadData[6],ArrayReg[6],ReadRegister);
mux32to1 mux7(ReadData[7],ArrayReg[7],ReadRegister);
mux32to1 mux8(ReadData[8],ArrayReg[8],ReadRegister);
mux32to1 mux9(ReadData[9],ArrayReg[9],ReadRegister);
mux32to1 mux10(ReadData[10],ArrayReg[10],ReadRegister);
mux32to1 mux11(ReadData[11],ArrayReg[11],ReadRegister);
mux32to1 mux12(ReadData[12],ArrayReg[12],ReadRegister);
mux32to1 mux13(ReadData[13],ArrayReg[13],ReadRegister);
mux32to1 mux14(ReadData[14],ArrayReg[14],ReadRegister);
mux32to1 mux15(ReadData[15],ArrayReg[15],ReadRegister);
mux32to1 mux16(ReadData[16],ArrayReg[16],ReadRegister);
mux32to1 mux17(ReadData[17],ArrayReg[17],ReadRegister);
mux32to1 mux18(ReadData[18],ArrayReg[18],ReadRegister);
mux32to1 mux19(ReadData[19],ArrayReg[19],ReadRegister);
mux32to1 mux20(ReadData[20],ArrayReg[20],ReadRegister);
mux32to1 mux21(ReadData[21],ArrayReg[21],ReadRegister);
mux32to1 mux22(ReadData[22],ArrayReg[22],ReadRegister);
mux32to1 mux23(ReadData[23],ArrayReg[23],ReadRegister);
mux32to1 mux24(ReadData[24],ArrayReg[24],ReadRegister);
mux32to1 mux25(ReadData[25],ArrayReg[25],ReadRegister);
mux32to1 mux26(ReadData[26],ArrayReg[26],ReadRegister);
mux32to1 mux27(ReadData[27],ArrayReg[27],ReadRegister);
mux32to1 mux28(ReadData[28],ArrayReg[28],ReadRegister);
mux32to1 mux29(ReadData[29],ArrayReg[29],ReadRegister);
mux32to1 mux30(ReadData[30],ArrayReg[30],ReadRegister);
mux32to1 mux31(ReadData[31],ArrayReg[31],ReadRegister);
endmodule
module alu(Output, CarryOut, zero, overflow, negative, BussA, BussB, ALUControl);
output CarryOut,overflow,negative,zero;
output [31:0] Output;
input [31:0] BussA,BussB;
input [1:0] ALUControl;
wire lessthan;
wire [31:0] crrout;
alu1bit alu0(Output[0],crrout[0],BussA[0],BussB[0],ALUControl[1],lessthan,ALUControl);
alu1bit alu1(Output[1],crrout[1],BussA[1],BussB[1],crrout[0],1'b0,ALUControl);
alu1bit alu2(Output[2],crrout[2],BussA[2],BussB[2],crrout[1],1'b0,ALUControl);
alu1bit alu3(Output[3],crrout[3],BussA[3],BussB[3],crrout[2],1'b0,ALUControl);
alu1bit alu4(Output[4],crrout[4],BussA[4],BussB[4],crrout[3],1'b0,ALUControl);
alu1bit alu5(Output[5],crrout[5],BussA[5],BussB[5],crrout[4],1'b0,ALUControl);
alu1bit alu6(Output[6],crrout[6],BussA[6],BussB[6],crrout[5],1'b0,ALUControl);
alu1bit alu7(Output[7],crrout[7],BussA[7],BussB[7],crrout[6],1'b0,ALUControl);
alu1bit alu8(Output[8],crrout[8],BussA[8],BussB[8],crrout[7],1'b0,ALUControl);
alu1bit alu9(Output[9],crrout[9],BussA[9],BussB[9],crrout[8],1'b0,ALUControl);
alu1bit alu10(Output[10],crrout[10],BussA[10],BussB[10],crrout[9],1'b0,ALUControl);
alu1bit alu11(Output[11],crrout[11],BussA[11],BussB[11],crrout[10],1'b0,ALUControl);
alu1bit alu12(Output[12],crrout[12],BussA[12],BussB[12],crrout[11],1'b0,ALUControl);
alu1bit alu13(Output[13],crrout[13],BussA[13],BussB[13],crrout[12],1'b0,ALUControl);
alu1bit alu14(Output[14],crrout[14],BussA[14],BussB[14],crrout[13],1'b0,ALUControl);
alu1bit alu15(Output[15],crrout[15],BussA[15],BussB[15],crrout[14],1'b0,ALUControl);
alu1bit alu16(Output[16],crrout[16],BussA[16],BussB[16],crrout[15],1'b0,ALUControl);
alu1bit alu17(Output[17],crrout[17],BussA[17],BussB[17],crrout[16],1'b0,ALUControl);
alu1bit alu18(Output[18],crrout[18],BussA[18],BussB[18],crrout[17],1'b0,ALUControl);
alu1bit alu19(Output[19],crrout[19],BussA[19],BussB[19],crrout[18],1'b0,ALUControl);
alu1bit alu20(Output[20],crrout[20],BussA[20],BussB[20],crrout[19],1'b0,ALUControl);
alu1bit alu21(Output[21],crrout[21],BussA[21],BussB[21],crrout[20],1'b0,ALUControl);
alu1bit alu22(Output[22],crrout[22],BussA[22],BussB[22],crrout[21],1'b0,ALUControl);
alu1bit alu23(Output[23],crrout[23],BussA[23],BussB[23],crrout[22],1'b0,ALUControl);
alu1bit alu24(Output[24],crrout[24],BussA[24],BussB[24],crrout[23],1'b0,ALUControl);
alu1bit alu25(Output[25],crrout[25],BussA[25],BussB[25],crrout[24],1'b0,ALUControl);
alu1bit alu26(Output[26],crrout[26],BussA[26],BussB[26],crrout[25],1'b0,ALUControl);
alu1bit alu27(Output[27],crrout[27],BussA[27],BussB[26],crrout[26],1'b0,ALUControl);
alu1bit alu28(Output[28],crrout[28],BussA[28],BussB[28],crrout[27],1'b0,ALUControl);
alu1bit alu29(Output[29],crrout[29],BussA[29],BussB[29],crrout[28],1'b0,ALUControl);
alu1bit alu30(Output[30],crrout[30],BussA[30],BussB[30],crrout[29],1'b0,ALUControl);
alu1bit alu31(Output[31],crrout[31],BussA[31],BussB[31],crrout[30],1'b0,ALUControl);
not #(50) notcarry(notcr31,crrout[31]);
// Carryout = Not carry out 31 if it is subtraction
mux21 muxcarry31(CarryOut,crrout[31],notcr31,ALUControl[1]);
xor #(50) xor5(overflow,crrout[30],crrout[31]);
// SLT
addsub add2(addsub31Out,crrout31,BussA[31],BussB[31],crrout[30],ALUControl[1]);
xor #(50) xor6(lessthan,overflow,addsub31Out);
assign negative = Output[31];
or #(50) or1(o1,Output[0],Output[1],Output[2],Output[3]);
or #(50) or2(o2,Output[4],Output[5],Output[6],Output[7]);
or #(50) or3(o3,Output[8],Output[9],Output[10],Output[11]);
or #(50) or4(o4,Output[12],Output[13],Output[14],Output[15]);
or #(50) or5(o5,Output[16],Output[17],Output[18],Output[19]);
or #(50) or6(o6,Output[20],Output[21],Output[22],Output[23]);
or #(50) or7(o7,Output[24],Output[25],Output[26],Output[27]);
or #(50) or8(o8,Output[28],Output[29],Output[30],Output[31]);
or #(50) or9(o9,o1,o2,o3,o4);
or #(50) or10(o10,o5,o6,o7,o8);
nor #(50) nor1(zero,o9,o10);
endmodule
module alu1bit(result,crrout,a,b,carryin,less,ALUControl);
output result,crrout;
input a,b,carryin,less;
addsub add1(addsubOut,crrout,a,b,carryin,ALUControl[1]);
xor #(50) xor1(xorOut,a,b);
mux21 mux2(xorlessOut,xorOut,less,ALUControl[1]);
mux21 mux3(result,addsubOut,xorlessOut,ALUControl[0]);
endmodule
module addsub(Out,cout,a,b,cin,select);
input a,b,cin,select;
output Out,cout; // the result and carry out
not #(50) not1(notb,b);
mux21 mux1(b1,b,notb,select);
adder adder1(Out,cout,a,b1,cin);
endmodule
module adder(sum,cout,a,b,cin);
input a,b,cin;
output cout,sum;
endmodule
module mux21(O,A,B,sel);
// sel = 0 thi O = A
// sel = 1 thi O =B
output O;
input A,B,sel;
not #(50) not1(nsel,sel);
and #(50) and1(O1,A,nsel);
and #(50) and2(O2,B,sel);
or #(50) or2(O,O1,O2);
endmodule
module dataMem(data, address, writedata, writeenable,MemRead,clk);
input [31:0] address, writedata;
input writeenable,MemRead, clk;
output [31:0] data;
reg [7:0] datamem[1023:0];
reg [31:0] temp;
buf #1000 buf0(data[0],temp[0]),
buf1(data[1],temp[1]),
buf2(data[2],temp[2]),
buf3(data[3],temp[3]),
buf4(data[4],temp[4]),
buf5(data[5],temp[5]),
buf6(data[6],temp[6]),
buf7(data[7],temp[7]),
buf8(data[8],temp[8]),
buf9(data[9],temp[9]),
buf10(data[10],temp[10]),
buf11(data[11],temp[11]),
buf12(data[12],temp[12]),
buf13(data[13],temp[13]),
buf14(data[14],temp[14]),
buf15(data[15],temp[15]),
buf16(data[16],temp[16]),
buf17(data[17],temp[17]),
buf18(data[18],temp[18]),
buf19(data[19],temp[19]),
buf20(data[20],temp[20]),
buf21(data[21],temp[21]),
buf22(data[22],temp[22]),
buf23(data[23],temp[23]),
buf24(data[24],temp[24]),
buf25(data[25],temp[25]),
buf26(data[26],temp[26]),
buf27(data[27],temp[27]),
buf28(data[28],temp[28]),
buf29(data[29],temp[29]),
buf30(data[30],temp[30]),
buf31(data[31],temp[31]);
always @(posedge clk)
if (writeenable)
begin
datamem[address]=writedata[31:24];
datamem[address+1]=writedata[23:16];
datamem[address+2]=writedata[15:8];
datamem[address+3]=writedata[7:0];
end
always @(address or datamem[address] or datamem[address+1] or datamem[address+2] or datamem[address+3])
begin
temp={datamem[address],datamem[address+1],datamem[address+2],datamem[address+3]};
end
// initial
// begin
// $readmemh("data.dat", datamem);
// end
endmodule
// Zero-Extension
module zero_extend(zOut32,zIn16);
output [31:0] zOut32;
input [15:0] zIn16;
assign zOut32 = {{16{1'b0}},zIn16};
endmodule
module mux2x32to32( DataOut,Data0, Data1, Select);
output [31:0] DataOut; // Data Out
input [31:0] Data0, Data1; // Data In 1 and 2
input Select;
// neu Select = 0 thi DataOut = Data0
// nguoc lai thi DataOut = Data1
mux2_1 mux0(DataOut[0],Data0[0],Data1[0],Select);
mux2_1 mux1(DataOut[1],Data0[1],Data1[1],Select);
mux2_1 mux2(DataOut[2],Data0[2],Data1[2],Select);
mux2_1 mux3(DataOut[3],Data0[3],Data1[3],Select);
mux2_1 mux4(DataOut[4],Data0[4],Data1[4],Select);
mux2_1 mux5(DataOut[5],Data0[5],Data1[5],Select);
mux2_1 mux6(DataOut[6],Data0[6],Data1[6],Select);
mux2_1 mux7(DataOut[7],Data0[7],Data1[7],Select);
mux2_1 mux8(DataOut[8],Data0[8],Data1[8],Select);
mux2_1 mux9(DataOut[9],Data0[9],Data1[9],Select);
mux2_1 mux10(DataOut[10],Data0[10],Data1[10],Select);
mux2_1 mux11(DataOut[11],Data0[11],Data1[11],Select);
mux2_1 mux12(DataOut[12],Data0[12],Data1[12],Select);
mux2_1 mux13(DataOut[13],Data0[13],Data1[13],Select);
mux2_1 mux14(DataOut[14],Data0[14],Data1[14],Select);
mux2_1 mux15(DataOut[15],Data0[15],Data1[15],Select);
mux2_1 mux16(DataOut[16],Data0[16],Data1[16],Select);
mux2_1 mux17(DataOut[17],Data0[17],Data1[17],Select);
mux2_1 mux18(DataOut[18],Data0[18],Data1[18],Select);
mux2_1 mux19(DataOut[19],Data0[19],Data1[19],Select);
mux2_1 mux20(DataOut[20],Data0[20],Data1[20],Select);
mux2_1 mux21(DataOut[21],Data0[21],Data1[21],Select);
mux2_1 mux22(DataOut[22],Data0[22],Data1[22],Select);
mux2_1 mux23(DataOut[23],Data0[23],Data1[23],Select);
mux2_1 mux24(DataOut[24],Data0[24],Data1[24],Select);
mux2_1 mux25(DataOut[25],Data0[25],Data1[25],Select);
mux2_1 mux26(DataOut[26],Data0[26],Data1[26],Select);
mux2_1 mux27(DataOut[27],Data0[27],Data1[27],Select);
mux2_1 mux28(DataOut[28],Data0[28],Data1[28],Select);
mux2_1 mux29(DataOut[29],Data0[29],Data1[29],Select);
mux2_1 mux30(DataOut[30],Data0[30],Data1[30],Select);
mux2_1 mux31(DataOut[31],Data0[31],Data1[31],Select);
endmodule
module sign_extend(sOut32,sIn16);
output [31:0] sOut32;
input [15:0] sIn16;
assign sOut32 = {{16{sIn16[15]}},sIn16};
endmodule
// Shift left 2 module
module shift_left_2(Out32, In32);
output [31:0] Out32;
input [31:0] In32;
assign Out32 = {In32[29:0],2'b00};
endmodule
module mux2x5to5( AddrOut,Addr0, Addr1, Select);
output [4:0] AddrOut; // Address Out
input [4:0] Addr0, Addr1; // Address In 1 and 2
input Select;
mux21 mux0(AddrOut[0],Addr0[0],Addr1[0],Select);
mux21 mux1(AddrOut[1],Addr0[1],Addr1[1],Select);
mux21 mux2(AddrOut[2],Addr0[2],Addr1[2],Select);
mux21 mux3(AddrOut[3],Addr0[3],Addr1[3],Select);
mux21 mux4(AddrOut[4],Addr0[4],Addr1[4],Select);
endmodule
module mux2_1(O,A,B,sel);
// sel = 0 : O = A
// sel = 1 : O =B
output O;
input A,B,sel;
endmodule
// Control unit
module Control(
RegDst,
ALUSrc,
MemtoReg,
RegWrite,
MemRead,
MemWrite,
Branch,
ALUOp,
Jump,
SignZero,
Opcode
output RegDst,ALUSrc,MemtoReg,RegWrite,MemRead,MemWrite,Branch,Jump,SignZero;
output [1:0] ALUOp;
input [5:0] Opcode;
reg RegDst,ALUSrc,MemtoReg,RegWrite,MemRead,MemWrite,Branch,Jump,SignZero;
reg [1:0] ALUOp;
always @(*)
casex (Opcode)
6'b000000 : begin // R - type
RegDst = 1'b1;
ALUsrc=1'b0;
MemtoReg= 1'b0;
RegWrite= 1'b1;
MemRead = 1'b0;
MemWrite= 1'b0;
Branch = 1'b0;
ALUOp = 2'b10;
Jump = 1'b0;
SignZero= 1'b0;
end
6'b100011 : begin // lw - load word
RegDst = 1'b0;
ALUsrc=1'b1;
MemtoReg= 1'b1;
RegWrite= 1'b1;
MemRead = 1'b1;
MemWrite= 1'b0;
Branch = 1'b0;
ALUOp = 2'b00;
Jump = 1'b0;
SignZero= 1'b0; // sign extend
end
6'b101011 : begin // sw - store word
RegDst = 1'bx;
ALUsrc=1'b1;
MemtoReg= 1'bx;
RegWrite= 1'b0;
MemRead = 1'b0;
MemWrite= 1'b1;
Branch = 1'b0;
ALUOp = 2'b00;
Jump = 1'b0;
SignZero= 1'b0;
end
6'b000101 : begin // bne - branch if not equal
RegDst = 1'b0;
ALUsrc=1'b0;
MemtoReg= 1'b0;
RegWrite= 1'b0;
MemRead = 1'b0;
MemWrite= 1'b0;
Branch = 1'b1;
ALUOp = 2'b01;
Jump = 1'b0;
end
6'b001110 : begin // XORI - XOR immidiate
RegDst = 1'b0;
ALUsrc=1'b1;
MemtoReg= 1'b0;
RegWrite= 1'b1;
MemRead = 1'b0;
MemWrite= 1'b0;
Branch = 1'b0;
ALUOp = 2'b11;
Jump = 1'b0;
SignZero= 1'b1; // zero extend
end
6'b000010 : begin // j - Jump
RegDst = 1'b0;
ALUsrc=1'b0;
MemtoReg= 1'b0;
RegWrite= 1'b0;
MemRead = 1'b0;
MemWrite= 1'b0;
Branch = 1'b0;
ALUOp = 2'b00;
Jump = 1'b1;
SignZero= 1'b0;
end
default : begin
RegDst = 1'b0;
ALUsrc=1'b0;
MemtoReg= 1'b0;
RegWrite= 1'b0;
MemRead = 1'b0;
MemWrite= 1'b0;
Branch = 1'b0;
ALUOp = 2'b10;
Jump = 1'b0;
SignZero= 1'b0;
end
endcase
endmodule
// ALU Control unit
module ALUControl_Block( ALUControl, ALUOp, Function);
output [1:0] ALUControl;
reg [1:0] ALUControl;
input [1:0] ALUOp;
input [5:0] Function;
wire [7:0] ALUControlIn;
assign ALUControlIn = {ALUOp,Function};
always @(ALUControlIn)
casex (ALUControlIn)
8'b11xxxxxx: ALUControl=2'b01;
8'b00xxxxxx: ALUControl=2'b00;
8'b01xxxxxx: ALUControl=2'b10;
8'b10100000: ALUControl=2'b00;
8'b10100010: ALUControl=2'b10;
8'b10101010: ALUControl=2'b11;
default: ALUControl=2'b00;
endcase
endmodule
// Control singals for JR instruction
module JRControl_Block( JRControl, ALUOp, Function);
output JRControl;
reg JRControl;
input [1:0] ALUOp;
wire [7:0] test;
assign test = {ALUOp,Function};
always @(test)
case (test)
8'b10001000 : JRControl=1'b1;
default: JRControl=1'b0;
endcase
endmodule
// Forwarding Unit
module ForwardingUnit(ForwardA,ForwardB,MEM_RegWrite,WB_RegWrite,MEM_WriteRegister,WB_WriteRegister,EX_rs,EX_rt);
output [1:0] ForwardA,ForwardB;
input MEM_RegWrite,WB_RegWrite;
input [4:0] MEM_WriteRegister,WB_WriteRegister,EX_rs,EX_rt;
// a= 1 if ( MEM_WriteRegister != 0 )
or #(50) orMEM_WriteReg(a,MEM_WriteRegister[4],MEM_WriteRegister[3],MEM_WriteRegister[2],MEM_WriteRegister[1],MEM_WriteRegister[0]);
CompareAddress CompMEM_WriteReg_EXrs(b,MEM_WriteRegister,EX_rs);
and #(50) andx(x,MEM_RegWrite,a,b);
// x=1 if ((MEM_RegWrite==1)&&(MEM_WriteRegister != 0)&&(MEM_WriteRegister==EX_rs))
// c= 1 if ( WB_WriteRegister != 0 )
or #(50) orWB_WriteReg(c,WB_WriteRegister[4],WB_WriteRegister[3],WB_WriteRegister[2],WB_WriteRegister[1],WB_WriteRegister[0]);
CompareAddress CompWB_WriteReg_EXrs(d,WB_WriteRegister,EX_rs);
and #(50) andy(y,WB_RegWrite,c,d);
// y=1 if ((WB_RegWrite==1)&&(WB_WriteRegister != 0)&&(WB_WriteRegister==EX_rs))
// ForwardA[1] = x; va ForwardA[0] = (NOT x). y ;
assign ForwardA[1] = x;
not #(50) notxgate(notx,x);
and #(50) NOTxANDy(ForwardA[0],notx,y);
// ForwardB
CompareAddress CompMEM_WriteReg_EXrt(b1,MEM_WriteRegister,EX_rt);
CompareAddress CompWB_WriteReg_EXrt(d1,WB_WriteRegister,EX_rt);
and #(50) andx1(x1,MEM_RegWrite,a,b1);
and #(50) andy1(y1,WB_RegWrite,c,d1);
assign ForwardB[1] = x1;
not #(50) notx1gate(notx1,x1);
and #(50) NOTx1ANDy1(ForwardB[0],notx1,y1);
endmodule
// mux3x32to32
module mux3x32to32(DataOut,A,B,C,Select);
input [1:0] Select;
input [31:0] A,B,C;
wire [31:0] DataOut1,DataOut2;
mux2x32to32 muxAB(DataOut1,A,B, Select[1]);
mux2x32to32 muxCA(DataOut2,C,A, Select[1]);
mux2x32to32 muxABC(DataOut,DataOut1,DataOut2, Select[0]);
endmodule
// Stall Control
module StallControl(PC_WriteEn,IFID_WriteEn,Stall_flush,EX_MemRead,EX_rt,ID_rs,ID_rt,ID_Op);
output PC_WriteEn,IFID_WriteEn,Stall_flush;
wire PC_WriteEn,IFID_WriteEn,Stall_flush;
input EX_MemRead,EX_rt,ID_rs,ID_rt;
input [5:0] ID_Op;
wire [4:0] EX_rt,ID_rs,ID_rt,xorRsRt,xorRtRt;
wire [5:0] xoropcodelw,xoropcodexori;
wire EX_MemRead;
//wire xoropcode1,xoroprt;
// write in behavior model
/*always @(EX_MemRead or EX_rt or ID_rs or ID_rt)
begin
if ((EX_MemRead==1)&&((EX_rt==ID_rs)||((EX_rt==ID_rt)&&(Opcode!= 6'b001110)&&(Opcode!= 6'b100011)))
begin
PC_WriteEn=1'b0;
IFID_WriteEn=1'b0;
Stall_flush =1'b1;
end
else
begin
PC_WriteEn=1'b1;
IFID_WriteEn=1'b1;
Stall_flush =1'b0;
end
end
// write in structural model
xor #(50) xorRsRt4(xorRsRt[4],EX_rt[4],ID_rs[4]);
xor #(50) xorRsRt3(xorRsRt[3],EX_rt[3],ID_rs[3]);
xor #(50) xorRsRt2(xorRsRt[2],EX_rt[2],ID_rs[2]);
xor #(50) xorRsRt1(xorRsRt[1],EX_rt[1],ID_rs[1]);
xor #(50) xorRsRt0(xorRsRt[0],EX_rt[0],ID_rs[0]);
or #(50) OrRsRt1(OrRsRt,xorRsRt[4],xorRsRt[3],xorRsRt[2],xorRsRt[1],xorRsRt[0]);
not #(50) notgate1(notOrRsRt,OrRsRt);
// neu EX_rt==ID_rs thi notOrRsRt = 1
xor #(50) xorRtRt4(xorRtRt[4],EX_rt[4],ID_rt[4]);
xor #(50) xorRtRt3(xorRtRt[3],EX_rt[3],ID_rt[3]);
xor #(50) xorRtRt2(xorRtRt[2],EX_rt[2],ID_rt[2]);
xor #(50) xorRtRt1(xorRtRt[1],EX_rt[1],ID_rt[1]);
xor #(50) xorRtRt0(xorRtRt[0],EX_rt[0],ID_rt[0]);
or #(50) OrRtRt1(OrRtRt,xorRtRt[4],xorRtRt[3],xorRtRt[2],xorRtRt[1],xorRtRt[0]);
not #(50) notgate2(notOrRtRt,OrRtRt);
// neu EX_rt==ID_rt thi notOrRtRt = 1
xor #(50) xoropcode5(xoropcodelw[5],ID_Op[5],1'b1);
xor #(50) xoropcode4(xoropcodelw[4],ID_Op[4],1'b0);
xor #(50) xoropcode3(xoropcodelw[3],ID_Op[3],1'b0);
xor #(50) xoropcode2(xoropcodelw[2],ID_Op[2],1'b0);
xor #(50) xoropcode1(xoropcodelw[1],ID_Op[1],1'b1);
xor #(50) xoropcode0(xoropcodelw[0],ID_Op[0],1'b1);
or #(50) oropcode1(ec1,xoropcodelw[5],xoropcodelw[4],xoropcodelw[3],xoropcodelw[2],xoropcodelw[1],xoropcodelw[0]);
// opcode != opcode[lw] xoropcodelw =1
xor #(50) xoropcod5(xoropcodexori[5],ID_Op[5],1'b0);
xor #(50) xoropcod4(xoropcodexori[4],ID_Op[4],1'b0);
xor #(50) xoropcod3(xoropcodexori[3],ID_Op[3],1'b1);
xor #(50) xoropcod2(xoropcodexori[2],ID_Op[2],1'b1);
xor #(50) xoropcod1(xoropcodexori[1],ID_Op[1],1'b1);
xor #(50) xoropcod0(xoropcodexori[0],ID_Op[0],1'b0);
or #(50) oropcode2(ec2,xoropcodexori[5],xoropcodexori[4],xoropcodexori[3],xoropcodexori[2],xoropcodexori[1],xoropcodexori[0]);
// opcode != opcode[xori] xoropcodexori =1
and #(50) and1(xorop,ec1,ec2);
and #(50) and2(xoroprt,xorop,notOrRtRt);
or #(50) OrEXIDRsRt(OrOut,notOrRsRt,xoroprt);
and #(50) AndCondition(Condition,EX_MemRead,OrOut);
// Condition =1 when stall is satisfied
not #(50) NotPC_WriteEn(PC_WriteEn,Condition);
not #(50) NotIFID_WriteEn(IFID_WriteEn,Condition);
buf #(50) bufStallflush(Stall_flush,Condition);
endmodule
// Flush control signals
module flush_block(
ID_RegDst,ID_ALUSrc, ID_MemtoReg,ID_RegWrite,ID_MemRead,ID_MemWrite,
ID_Branch,ID_ALUOp,ID_JRControl,flush,RegDst,ALUSrc,MemtoReg,RegWrite,
output ID_RegDst,ID_ALUSrc,ID_MemtoReg,ID_RegWrite,ID_MemRead,ID_MemWrite,ID_Branch,ID_JRControl;
output [1:0] ID_ALUOp;
input flush,RegDst,ALUSrc,MemtoReg,RegWrite,MemRead,MemWrite,Branch,JRControl;
input [1:0] ALUOp;
not #50 (notflush,flush);
and #50 and1(ID_RegDst,RegDst,notflush);
and #50 and2(ID_ALUSrc,ALUSrc,notflush);
and #50 and3(ID_MemtoReg,MemtoReg,notflush);
and #50 and4(ID_RegWrite,RegWrite,notflush);
and #50 and5(ID_MemRead,MemRead,notflush);
and #50 and6(ID_MemWrite,MemWrite,notflush);
and #50 and7(ID_Branch,Branch,notflush);
and #50 and8(ID_JRControl,JRControl,notflush);
and #50 and9(ID_ALUOp[1],ALUOp[1],notflush);
and #50 and10(ID_ALUOp[0],ALUOp[0],notflush);
endmodule
// Discard instructions when needed
module Discard_Instr(ID_flush,IF_flush,jump,bne,jr);
output ID_flush,IF_flush;
input jump,bne,jr;
or #50 OR1(IF_flush,jump,bne,jr);
or #50 OR2(ID_flush,bne,jr);
endmodule
// Write Back Forwarding
module WB_forward(ReadData1Out,ReadData2Out,ReadData1,ReadData2,rs,rt,WriteRegister,WriteData,RegWrite);
// WB Hazard: Reading data while writing
// Solve Hazard at the WriteBack Stage
output [31:0] ReadData1Out,ReadData2Out;
input [31:0] ReadData1,ReadData2,WriteData;
input [4:0] rs,rt,WriteRegister;
input RegWrite;
wire ReadSourceRs,ReadSourceRt;
wire compOut1,compOut2;
// behavior model
always @(rs or rt or WriteRegister or WriteData or RegWrite)
begin
if ((RegWrite==1)&&(WriteRegister != 0)&&(WriteRegister==rs))
ReadSourceRs = 1'b1; //Forwarding WriteData to ReadData1
else
ReadSourceRs = 1'b0;
if ((RegWrite==1)&&(WriteRegister != 0)&&(WriteRegister==rt))
ReadSourceRt = 1'b1; //Forwarding WriteData to ReadData2
else
ReadSourceRt = 1'b0;
end
// Structural model
or #(50) orWriteReg(orOut1,WriteRegister[4],WriteRegister[3],WriteRegister[2],WriteRegister[1],WriteRegister[0]);
CompareAddress Compare1(compOut1,WriteRegister,rs);
and #(50) andCondition1(ReadSourceRs,RegWrite,orOut1,compOut1);
CompareAddress Compare2(compOut2,WriteRegister,rt);
and #(50) andCondition2(ReadSourceRt,RegWrite,orOut1,compOut2);
mux2x32to32 muxReadData1( ReadData1Out,ReadData1,WriteData, ReadSourceRs);
mux2x32to32 muxReadData2( ReadData2Out,ReadData2,WriteData, ReadSourceRt);
endmodule
// Compare Address
module CompareAddress(equal,Addr1,Addr2);
output equal;
wire equal;
input [4:0] Addr1,Addr2;
wire [4:0] Addr1,Addr2,xorAddress;
xor #(50) xorAddress4(xorAddress[4],Addr1[4],Addr2[4]);
xor #(50) xorAddress3(xorAddress[3],Addr1[3],Addr2[3]);
xor #(50) xorAddress2(xorAddress[2],Addr1[2],Addr2[2]);
xor #(50) xorAddress1(xorAddress[1],Addr1[1],Addr2[1]);
xor #(50) xorAddress0(xorAddress[0],Addr1[0],Addr2[0]);
or #(50) Orgate1(OrAddr,xorAddress[4],xorAddress[3],xorAddress[2],xorAddress[1],xorAddress[0]);
not #(50) notgate1(equal,OrAddr);
endmodule
Scholar u4223374
Re: ERROR:Map:116 - The design is empty. No processing will be done
I will take a guess and say that your inputs/outputs are not connected to anything external. If they're not connected, Vivado just optimizes the whole design away completely.
Visitor kshitij_10
Teacher drjohnsmith
lets see your test bench
what device you mapping this to ?
what other experience have you had with these tools ?
