ERROR:Place:1136 - This design contains a global buffer instance
hi, can anyone tellme how to fix this error.
ERROR:Place:1136 - This design contains a global buffer instance,
<RST_N_BUFGP/BUFG>, driving the net, <RST_N_BUFGP>, that is driving the
following (first 30) non-clock load pins.
< PIN:
Inst_edk_pci/plbv46_pci_0/plbv46_pci_0/I_pci2plb_bridge/I_mst_ipifv3_bridge/I
_ipif_mst_req_sm/I_ipif_mst_wrreq_sm/Reset_PCIside_Clear_src_dsc_occurred_OR_
952_o.A1; >
< PIN:
_ipif_mst_req_sm/I_ipif_mst_rdreq_sm/PCI_Prefetch_SM_cs_FSM_FFd2_rstpot.A3; >
< PIN:
_ipif_mst_req_sm/_n01901.A2; >
< PIN:
Inst_edk_pci/plbv46_pci_0/plbv46_pci_0/I_plb2pci_bridge/I_slv_ipifv3_bridge/I
_slv_ipif2pci_fifo/I_slv_ipif2pci_fifo_cntrl/Wr_ABus_MSB_Reset_Rd_side1.A4; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/Reset_PCIside_GND_399_o_OR_336_o1.A1
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/Mmux_PCI_initiator_SM_ns[3]_PWR_86_o
_mux_103_OUT31_G.A3; >
< PIN:
_mux_103_OUT31_F.A3; >
< PIN:
_ipif_mst_req_sm/I_ipif_mst_rdreq_sm/discard_count_31_glue_rst.A2; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/Only_2_in_FIFO_rstpot.A1; >
< PIN:
_ipif_mst_req_sm/I_ipif_mst_wrreq_sm/Rmt_PCI_init_wr_IPIF_InProg_PCIside_int_
rstpot1.A3; >
< PIN:
_slv_ipif2pci_fifo/I_slv_ipif2pci_fifo_cntrl/Wr_ABus_MSB_Wr_side_D.A3; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/Last_wrd_in_FIFO_not_loaded_in_V3cor
e_rstpot.A2; >
< PIN:
_ipif_mst_req_sm/I_ipif_mst_wrreq_sm/Set_srcrdy_sof_eof_cs_glue_set.A1; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_wr_initiator_pciretry_sm/PCI_Wr_Abort_prompt_i
nt_rstpot.A5; >
< PIN:
_ipif_mst_req_sm/I_ipif_mst_rdreq_sm/PCI_Prefetch_SM_cs_FSM_FFd9_rstpot.A4; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_addr_counter/IPIF_HIGHADDR_14_rstpot1.A6; >
< PIN:
Inst_edk_pci/plbv46_pci_0/plbv46_pci_0/I_plb2pci_bridge/I_slv_ipifv3_bridge/P
CI2IPIF_FIFO_Reset_PCIside_gtd1.A1; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/Reset_PCIside_Clear_IPIF2PCI_FIFO_Re
set_PCIinit_OR_342_o1.A2; >
< PIN:
_ipif_mst_req_sm/I_ipif_mst_rdreq_sm/IP2Bus_MstRd_dst_dsc_n_reg_rstpot.A5; >
< PIN:
Inst_edk_pci/plbv46_pci_0/plbv46_pci_0/PCI_CORE_S6_generate.pci_core_s6/RST1_
INV_0.A6; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_addr_counter/Pass_Request_rstpot.A3; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/PCI_initiator_SM_cs_FSM_FFd1-In42.A1
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/PCI_initiator_SM_cs_FSM_FFd3-In11.A1
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/PCI_initiator_SM_cs<3>1_SW3.A1; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/PCI_initiator_SM_cs<3>1_SW0.A1; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/PCI_initiator_SM_cs<3>1_SW1.A1; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/PCI_initiator_SM_cs<3>1_SW2.A1; >
< PIN:
_ipif_mst_req_sm/I_ipif_mst_rdreq_sm/s_Bus2IP_MstRd_eof_n_occurred_rstpot.A3;
< PIN:
_slv_ipif2pci_fifo/I_slv_ipif2pci_fifo_cntrl/Wr_ABus_MSB_Wr_side_G.A6; >
< PIN:
nclude_ipif_mst2pci_targ/I_pci_initiator/Reset_PCIside_GND_399_o_OR_345_o1_SW
0.A6; >This is not a recommended design practice in Spartan-6 due to
limitations in the global routing that may cause excessive delay, skew or
unroutable situations. It is recommended to only use a BUFG resource to
drive clock loads. If you wish to override this recommendation, you may use
the CLOCK_DEDICATED_ROUTE constraint (given below) in the .ucf file to demote
this message to a WARNING and allow your design to continue.
< PIN "RST_N_BUFGP/BUFG.O" CLOCK_DEDICATED_ROUTE = FALSE; >
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
Scholar drjohnsmith
Re: ERROR:Place:1136 - This design contains a global buffer instance
drive clock loads.
I have used this comment < PIN "RST_N_BUFGP/BUFG.O" CLOCK_DEDICATED_ROUTE = FALSE; > in .ucf file then it is coming different error like net not found in design
Scholar drjohnsmith
try it again please, and show us the results, and your ucf file.
please help me how to fix this errors
ok i used this comment again it came error as
ERROR:Place:1108 - A clock IOB / BUFGMUX clock component pair have been found
that are not placed at an optimal clock IOB / BUFGMUX site pair. The clock
IOB component <RST_N> is placed at site <D3>. The corresponding BUFG
component <RST_N_BUFGP/BUFG> is placed at site <BUFGMUX_X3Y8>. There is only
a select set of IOBs that can use the fast path to the Clocker buffer, and
they are not being used. You may want to analyze why this problem exists and
correct it. If this sub optimal condition is acceptable for this design, you
may use the CLOCK_DEDICATED_ROUTE constraint in the .ucf file to demote this
message to a WARNING and allow your design to continue. However, the use of
this override is highly discouraged as it may lead to very poor timing
results. It is recommended that this error condition be corrected in the
design. A list of all the COMP.PINs used in this clock placement rule is
listed below. These examples can be used directly in the .ucf file to
Scholar drjohnsmith
get rid of the \BUFG.O part of the command.
I might ask, the use of a BUFG and a none optimum pin is an oxcimorion.
One uses a bufg for speed, with its associated pin, using a none optimum pin slows the timming significanlty.
just get rid of the BUFG in the design would seme to have the same effect.
ok thank you sir, can you please tell me how to get rid of BUFG
Scholar drjohnsmith
have you tried the command I mentioned above ?
yes but problem not solved
can anyone tell me RST_N pin is compulsory for pci transaction
