ERROR:Place:1377 - Regional clock net for MIG with DDR3 in ML605 board
Hi All,
Tool : ISE 14.7,
Board : ML605,
Device : xc6vlx240t -1ff1156
  I am working with ML605 board, doing a project with DDR3. Sys_clk and ref_clk are provided by PLL.
So i have changed IBUFGs to BUFG. While implementation i got an error as follows:
"mig_inst/u_memc_ui_top/u_mem_intfc/phy_top0/clk_rsync<0>" is not routable
with loads locked in different clock regions such that it will be impossible
for the source to be routed to all loads. See below for a list of sample
locked components in each clock region. For more information on the clock
region rules, please refer to the architecture user's guide. To debug your
design with partially routed design, please allow mapper/placer to finish the
execution (by setting environment variable XIL_PAR_DEBUG_IOCLKPLACER to 1).
Musthafa
Hi All,
Finally, the issue is solved. We need to assign proper values for some parameters of MIG. The parameters and its values are given below.
nDQS_COL0               = 3,
nDQS_COL1               = 5,
DQS_LOC_COL0            = 24'h020100,
DQS_LOC_COL1            = 40'h0706050403.
By doing so errors are solved.
Musthafa
Cascaded PLL clock source is not recommended for MIG.
It looks you have modified the constraints generated with the core or locked the BUFG to a different clock region which you need to correct.
Satish
@musthafavakeri
Which IBUFG you have changed and in which file? can you show us the snapshot?
I would suggest to check if you have followed "BUFR Allocation Rules" given in UG406 and reallocate it
-Vanitha
Hi @musthafavakeri
In case if you have modified the MIG pinout after generating the IP then generate the MIG IP again using "verify ucf and update design" flow where you can load the PRJ and updated UCF file.
Deepika.
Hi Deepika,
I have tried in the way you suggested. But i got an error as follows:
ERROR: The same pin was allocated to more than one signal. Check the following:
Pin Name(L15) Signal: ddr3_ba[2]
Pin Name(L15) Signal: sys_clk
ERROR:Pins are not unique
I haven't mentioned LOC for sys_clk as its connected to the output of PLL. When I go with "create design" flow
no pins are matching for sys_clk. I got errors as "pin has multiple drivers" or the bank of the pin is not matching.
Musthafa
@musthafavakeri
As teh errors says all ocations constraints should have unique pins
Can you upload your project here to check the connectivity and errors?
Hi @musthafavakeri
I see that there are only two options provided for system clock "differential" and "single ended". There is no way to tell the MIG that you are using PLL to generate MIG system clock. This is the reason some pin is being allocated for system clock. See if the UCF file has LOC constraint on sys_clk pin and change it to some other pin to avoid the error.
Can't you drive the MIG system clock input from IO directly?
Deepika.
 Hi Satish,
I haven't modified any constraints other than MIG pin assignments.
Hi Vanitha,
The changes I have done are as follows:
1) changed IBUFG to BUFG in clk_ibuf.vhd
        se_input_clk : if(INPUT_CLK_TYPE = "SINGLE_ENDED") generate
-- SINGLE_ENDED input clock input buffers
-- u_ibufg_sys_clk : IBUFG --this line is commented and added next line
u_ibufg_sys_clk : BUFG
-- generic map(
-- IBUF_LOW_PWR => FALSE
port map(
I => sys_clk,
O => sys_clk_ibufg
end generate se_input_clk;
2) commented IBUFG and connected input and output of IBUFG directly in iodelay_ctrl.vhd
se_clk_ref: if (INPUT_CLK_TYPE = "SINGLE_ENDED") generate
-- u_ibufg_clk_ref : IBUFG
-- generic map (
-- port map (
-- I => clk_ref,
-- O => clk_ref_ibufg
end generate se_clk_ref;
--commented IBUFG and added line below
clk_ref_ibufg <= clk_ref;
This change is done as it gave error because two buffers are cascaded in this module.
Musthafa
@musthafavakeri
If you would like to drive the system clock from MMCM and not from external pins,  you need to comment out the IBUF/IBUG in infrastrrcuture module
Instead of going for additional MMCM, If you do not have same clock source as that of memory frequency, follow below AR for the changes
http://www.xilinx.com/support/answers/35242.html
This should work
Hope this helps
-Vanitha
Hi Deepika,
The oscillators available in the board are
  1) 200 MHz - differential
  2) 66 MHz - single ended.
So 200 MHz can be connected to sys_clk. But what about ref_clk...?
Deepika
200 MHz can be used for system and ref clocks, please check the AR that I posted in my earlier reply
Hi All,
I have tried many ways. But i got same error. So what I did is, I created a sample project of MIG with planahead 14.7
and modified the project as per my requirements. Its working.
One of my colleagues told me that ISE gives this error and its better to work in planahead. Is it right ?
Musthafa
Hi All,
nDQS_COL0               = 3,
nDQS_COL1               = 5,
Musthafa
Hi All,
Please note that above parameter values are specific to ML605 Board.
Musthafa
From where i will get these values ?
-Sampath
