Observer sandeep_sggs
ERROR_REPORT_HELP
Dear all,
             I am trying to do partial reconfiguration from tcl of ise 9.2. in final phase i m doing the map for top mudule. i get following log with error and the dcr fails. Can anybody pls tell how to get rid of this error:
% map top.ngd
Release 9.2i - Map J.36
Copyright (c) 1995-2007 Xilinx, Inc.  All rights reserved.
Using target part "5vlx50ff676-2".
Mapping design into LUTs...
Writing file top.ngm...
Constraining slice packing based on guide NCD.
Running directed packing...
Running delay-based LUT packing...
Running timing-driven packing...
Phase 1.1
Phase 1.1 (Checksum:9d4411) REAL time: 2 mins 24 secs
Phase 2.7
Phase 2.7 (Checksum:1312cfe) REAL time: 2 mins 24 secs
Phase 3.31
Phase 3.31 (Checksum:1c9c37d) REAL time: 2 mins 24 secs
Phase 4.33
Phase 4.33 (Checksum:26259fc) REAL time: 2 mins 24 secs
Phase 5.32
Phase 5.32 (Checksum:2faf07b) REAL time: 2 mins 24 secs
Phase 6.2
WARNING:Place:644 - A clock IOB clock component is not placed at an optimal
   clock IOB site. The clock IOB component <clkin_in> is placed at site <AB5>.
   The clock IO site can use the fast path between the IO and the Clock
   buffer/GCLK if the IOB is placed in the master Clock IOB Site. This is
   normally an ERROR but the environment variable
   XIL_PLACE_ALLOW_LOCAL_BUFG_ROUTING is set allowing your design to continue.
Phase 6.2 (Checksum:98a237) REAL time: 2 mins 42 secs
Phase 7.30
Phase 7.30 (Checksum:42c1d79) REAL time: 2 mins 42 secs
Phase 8.3
Phase 8.3 (Checksum:4c4b3f8) REAL time: 4 mins 26 secs
Phase 9.5
Phase 9.5 (Checksum:55d4a77) REAL time: 4 mins 26 secs
Phase 10.8
Phase 10.8 (Checksum:13a7248) REAL time: 12 mins 50 secs
Phase 11.29
Phase 11.29 (Checksum:68e7775) REAL time: 12 mins 50 secs
Phase 12.5
Phase 12.5 (Checksum:7270df4) REAL time: 12 mins 51 secs
Phase 13.18
Phase 13.18 (Checksum:7bfa473) REAL time: 17 mins 14 secs
Phase 14.5
Phase 14.5 (Checksum:8583af2) REAL time: 17 mins 15 secs
Phase 16.34
Phase 16.34 (Checksum:98967f0) REAL time: 17 mins 15 secs
REAL time consumed by placer: 17 mins 20 secs
CPU  time consumed by placer: 14 mins 51 secs
Inspecting route info ...
Route info done.
FATAL_ERROR:Pack:pktbamanager.c:1849:1.105.2.5 - Exception during DRC: Illegal
   physical DRC rule operation.   Process will terminate. For more information
   on this error, please consult the Answers Database or open a WebCase with
   this project attached at http://www.xilinx.com/support.
Design Summary
Number of errors   :   1
Number of warnings :   3
child process exited abnormally
thanks
sandeep
Historian
Historian
Re: ERROR_REPORT_HELP
The warning tells you what to do:
"WARNING:Place:644 - A clock IOB clock component is not placed at an optimal
   XIL_PLACE_ALLOW_LOCAL_BUFG_ROUTING is set allowing your design to continue"
So:
a) do NOT set that environment variable.
b) Put the clock on a proper clock I/O site (correct pin).
-a
Hi bassman59,
                        Is there any other remedy to get rid of that error ? can u tell if there is any......
sandeep
Historian
Historian
sandeep_sggs wrote:
Hi bassman59,
I'm sorry if you don't like my answer. The only other remedy is to simply not use the tools.
-a
  Hi bassman59,
                                 It's  not  a matter of  likes and dislikes.  And i did't  want to hurt, u if at all i did. U  r expert  and i asked whatever i felt.
Regrds,
Sandeep
Message Edited by sandeep_sggs on 03-01-2009 11:16 PM
