08-21-2012 01:59 AM
I'm using Xilinx ISE 14.2
Everything executed on the command line.
XST and build run fine.
Then I attempt map using the following map option:
map -p xc7v585t-ffg1761-1 (I've removed the rest of the command options for brevity)
and see the following error:
ERROR:Security:12 - No 'xc7v585t' feature version 2012.07 was available (-15), so 'WebPack' may not be used.
I tried changing the syntax of the part to:
map -p 7v585t-ffg1761-1
but I still see the same error.
I used partgen to determine the correct part syntax and it seems ok.
Any suggestions?
08-21-2012 05:05 AM
This looks like a license issue and the license paths are not set properly.
The license check is done in Map ,so the synthesis doesn't have any problem.
Are you using a webpack license?
Virtex 7 devices are not supported using Webpack license.
If you are using license other than webpack , make sure you set the license enivronmental variable point to the license file
example:
XILINXD_LICENSE_FILE = C:\.Xilinx\Xilinx.lic
