shaweikang1984
EXCEPTION_ACCESS_VIOLATION
I am using Vivado 2020.2.
I am trying to run a design on k7 325t. and i got the followed error every time I try to route the design.
Phase 2.4 Update Timing
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check 'J:/work/rs_proj/lz/camera_input/workdir/camera_input.runs/impl_1/hs_err_pid19348.log' for details
Unfortunately, the log file only contains:
# An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION)
Stack:
no stack trace available, please use hs_err_<pid>.dmp instead.
Thanks in advance.
Theory is grey,
and only the tree of life forever!
hongh
Please try the below parameter before routing:
set_param route.ignoreLocalClocks true
drjohnsmith
this is a pointer
https://forums.xilinx.com/t5/Synthesis/EXCEPTION-ACCESS-VIOLATION/td-p/1101646https://stackoverflow.com/questions/140030/possible-causes-of-java-vm-exception-access-violation
I'm afraid its JAVA..
welcome to the world of pain....
shaweikang1984
tried. not work.
Theory is grey,
syedz
@shaweikang1984
Can you try with different route_design directives? Try with Explore or AlternateCLBRouting.
If you can share post place dcp file, we can have a look and share workaround if crash is reproducible.
--Syed
shaweikang1984
i tried.
by now, the route directives "QUICK" is work. but the timing result is fail.
the dcp file is too big to upload. would u please send me an ezmove link?
Theory is grey,
hongh
drjohnsmith
@hongh some Voodo magic there ?
What does that command do ?
hongh
Just skipping a minor optional step in routing stage. If the final timing closure can be achieved, it can be accepted.
