giuseppe
Error implementation Vivado
Hi everyone,
I am trying to create a project in Vivado in which I have a user IP (generated starting from a block design) connected to the zynq.
When I perform the synthesis, I have some critical warning about BLACKBOXES, and this converts to an error when I run implementation.
Does anyone know something about this issue with BLACKBOXES?
jmcclusk
Mentor
Mentor
Blackboxes are missing modules in the design.   I'd say your user IP is not complete..  are you sure you included ALL the sources?
jmcclusk
Mentor
Mentor
hemangd
Hi @giuseppe,
Have a look into this ARs which may help you.
https://www.xilinx.com/support/answers/60975.html
https://www.xilinx.com/support/answers/60834.html
hemangd
hemangd
syedz
@giuseppe
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply to the thread.
--Syed
