Error when running implementation from exported project
I have created a project which works without any problems. Now I want to move it into a version control repository. For that I exported the project and the board design as a tcl script an added following lines to the project-tcl
source $origin_dir/design.tcl
set design_name [get_bd_designs]
make_wrapper -files [get_files $design_name.bd] -top -import
When I run the Implementation I get a Place 30-415 Error (IO Placement failed due to overutilization). The pinmapping is done by a constraint file.
Can anybody help me to fix this problem? Or is there any other workflow to put the project into version control?
Re: Error when running implementation from exported project
Thanks @rshekhaw  for your advice. With this change I was able to run the implementation step, but I was not able to create the bitstream.
I solved my issue with adding the wrapper-file to the project with the following lines. Then everything worked fine.
add_files -norecurse "$origin_dir/../$project_name/$project_name.srcs/sources_1/bd/toplevel/hdl/toplevel_wrapper.vhd"
set_property top toplevel_wrapper [current_fileset]
Hi @ainger.florian ,
Please check this AR# link:
https://www.xilinx.com/support/answers/58992.html
Raj
