Event counter in verilog
hi,
i'm a verilog beginner, i'm try to write a "event counter" on verilog.... this is my code, but it work only with "period" set to 16'b0000000000000001, if try set period to 16'b0000000000001000, result(out_event) is always '0'. Someone can help me to fix it ?
module mymodule(
    input  wire          clk,
    input  wire             enable,
    input  wire             reset,
    input    wire [15:0]        period,
    input    wire              in_event,
    output reg                  out_event
reg en = 1'b0;
reg re = 1'b0;
reg [15:0] count = 16'b0000000000000000;
always @(posedge clk) en <= enable;
always @(posedge clk) re <= reset;
always @(in_event)begin
if(in_event == 1'b1)begin
if(re)begin
    count <= 0 ;
    out_event <= 1'b0;
end else begin
    if(en) begin
        if(count == period-1)begin
            out_event <= 1'b1;
            count <= 0;
        end else begin
            count <=count + 1;
            out_event <= 1'b0;
        end
    end else begin
        out_event <= 1'b0;
    end
end
end else begin
    out_event <= 1'b0;
end
end
endmodule
thanks in advance
you need to sample the in_event only at a clock edge so instead of always @(in_event), you need always @(posedge clk) too:
always @(posedge clk) begin
if (reset)
count <= 0;
out_event <= 0;
else
count <= count + 1;
etc.
if (reset)
count <= 0;
out_event <= 0;
else
count <= count + 1;
etc.
Hi @marco_mion,
I am attaching the verilog code and testbench which is working for period 16'b0000000000001000.
I am attaching the snapshot of the testbench also.
Thanks and Regards,
Arpan
Arpan
Hi @marco_mion,
Thanks and Regards,
Arpan
Arpan
Hi, thanks Arpan for your help, my code work only in simulation but when synthesizes it did not work. I have solved rewriting all the code with.... always @(posedge clk) begin ...
