FPGA_implimentaion : not getting output on board
I'm working on kintex-7 fbg676-1,
currently in my design I'm running a 500MHZ clock(from differential input of 200MHZ, I'm generating 100MHz and from 100MHz I'm generating 500MHz), my aim is to get a strobe of 2ns, and I'm getting that in post-implementation simulation and pfa (all the timing constraints are also met.)
I'm not getting the strobe on the board.
what might be the reason?????
Voyager
Voyager
Re: FPGA_implimentaion : not getting output on board
Hey @yatish,
What is your output buffer and what IO standard do you use?
Without more information about the design, it's hard to tell, could be anything from ...
  • Wrong pin configuration
  • Misconfigured IO Buffer
  • Unpowered VCCO rail
  • Bad hardware or measurement
Best,
Herbert
-------------- Yes, I do this for fun!
Version:1.0 StartHTML:000000242 EndHTML:000019661 StartFragment:000019395 EndFragment:000019418 StartSelection:000019395 EndSelection:000019418 SourceURL:https://forums.xilinx.com/t5/forums/replypage/board-id/NewUser/message-id/48452Reply to Message - Community Forums Xilinx.com
  • pin configuration correct, I have given the 500MH clock generated from pll directly to that pin, its coming correctly
Version:1.0 StartHTML:000000242 EndHTML:000019750 StartFragment:000019484 EndFragment:000019507 StartSelection:000019484 EndSelection:000019507 SourceURL:https://forums.xilinx.com/t5/forums/replypage/board-id/NewUser/message-id/48452Reply to Message - Community Forums Xilinx.com
I have designed the code, I didn't get any errors, I thought it will work.
Version:1.0 StartHTML:000000242 EndHTML:000019832 StartFragment:000019570 EndFragment:000019589 StartSelection:000019570 EndSelection:000019589 SourceURL:https://forums.xilinx.com/t5/forums/replypage/board-id/NewUser/message-id/48452Reply to Message - Community Forums Xilinx.com
  • This one I don't know, if you tell which file you need, I will send you that
Version:1.0 StartHTML:000000242 EndHTML:000019926 StartFragment:000019656 EndFragment:000019683 StartSelection:000019656 EndSelection:000019683 SourceURL:https://forums.xilinx.com/t5/forums/replypage/board-id/NewUser/message-id/48452Reply to Message - Community Forums Xilinx.com
  • I don't think so, because my 500MHz clock is coming on the same pin , when I put the bit file on board, i'm getting constant166MHz pulse, which is not expected.
Version:1.0 StartHTML:000000242 EndHTML:000020118 StartFragment:000019734 EndFragment:000019885 StartSelection:000019734 EndSelection:000019881 SourceURL:https://forums.xilinx.com/t5/forums/replypage/board-id/NewUser/message-id/48452Reply to Message - Community Forums Xilinx.com
OBUF, 3.3V
Hi, I'm attaching code and constraints , please help me
