Fix Ports -> what does it mean?
Hi All,
In the Vivado IDE, in the I/O Ports tab of the Implemented Design, there is an option to select 'Fix Ports'. What does it exectly do?
Thank you!
Re: Fix Ports -> what does it mean?
Hi @dmitryl_home
Whatever pin assignment you have done when writing the physical constraints will be reflected under IO ports tab as fixed (selected). You can alos assign some other package pin from the drop down and save. Now re-run the implementation. The pin re-assignment for that port will be reflected under IO ports tab.
Rohit
Hi @dmitryl_home
Rohit
@dmitryl_home
If your query is addressed, Can you close this thread by marking the above post as "Accept as Solution"
--Syed
