Visitor laomar
Freeze design in vivado
hello,
i am working with vivado2018.2".
i made an example of code to initiate 4 LUT and to each lut i attribute a value
after that i run implementation and i generate bitstream to get ebc file (i saved this one) and i reinitiate the  4 LUTs by their complement i made the implementation and i generated the bitstream and i got a second ebc file.
in result to verify that it is correct when i compare the 2 ebc file i have to get (4*64 =256 bits that changed), but in my case i found 260.
So i need to freeze my design so that if i make any change in my code (initiate LUT) nothing change.
i tried with command lock_design and fix cell with pb block in  floorplannig but nothing happened.
thanks,
this my vhdl code:
library ieee;
use ieee.std_logic_1164.all;
library virtex;
entity lut is
port (
LUT1_IN, LUT2_IN : in std_logic_vector(1 downto 0);
LUT1_OUT, LUT2_OUT : out std_logic_vector(1 downto 0)
end entity lut;
architecture XILINX of LUT is
component LUT1
generic (INIT: bit_vector(1 downto 0) := "10");
port (O : out std_logic;
I0 : in std_logic);
end component;
component LUT2
generic (INIT: bit_vector(3 downto 0) := "0000");
I0, I1 : in std_logic);
end component;
begin
-- LUT1 used as an inverter
U0 : LUT1 generic map (INIT => "10")
port map (O => LUT1_OUT(0), I0 => LUT1_IN(0));
-- LUT1 used as a buffer
U1 : LUT1 generic map (INIT => "01")
port map (O => LUT1_OUT(1), I0 => LUT1_IN(1));
-- LUT2 used as a 2-input AND gate
U2 : LUT2 generic map (INIT => "0111")
port map (O => LUT2_OUT(0), I1 => LUT2_IN(1), I0 => LUT2_IN(0));
-- LUT2 used as a 2-input NAND gate
U3 : LUT2 generic map (INIT => "1000")
port map (O => LUT2_OUT(1), I1 => LUT2_IN(1), I0 => LUT2_IN(0));
end XILINX;
Re: Freeze design in vivado
You can apply dont_touch property with the wild card.
Ex:
set_property dont_touch true [get_cells -hier -filter {REF_NAME=~ LUT*}]
Hi, @laomar ,
If you just intend to modify the initial value of a LUT in your design without any change of other part of the design, you can open the routed.dcp and modify the INIT property of the target LUT directly.
Ex: set_property INIT 4'h6 [get_cells LUT_instance_name]
Visitor laomar
hi @hongh ,
thanks for your answer.
i do what u said and i modified my xdc file but always i found 260Bits as difference between the two ebc file.
Visitor laomar
hey,
i just added
set_property DONT_TOUCH TRUE [get_cells [list U0 U1 U2 U3]] in xdc file and it works now.
thanks,
Mariem
Hi, @laomar ,
"dont_touch" property helps the avoid optimization for the LUTs, such as LUT combine.
With the set_property command used on the netlist, you can only modify the initial value of LUT without touching any other thing in the design.
Visitor laomar
HI @hongh ,
That code was just an example to know how to initiate the 134600 lut of Artix 7: Xilinx part number XC7A200T-1SBG484C .
i am thinking to devide it into 8 part each part contain 16825 Luts.
am i  doing right?
in this case how can i use "don't touch" ?
thanks,
Ex:
