11-07-2020 11:53 PM - edited 11-07-2020 11:54 PM
Hello, I created a cutom IP named WEIGHT_INPUT_PROVIDER but it unexpectedly issue following warning message during implementation.
[DRC PDRC-153] Gated clock check: Net design_1_i/WEIGHT_INPUT_PROVIDER_0/inst/selection_inst/sel_reg_reg[1]_i_2_n_0 is a gated clock net sourced by a combinational pin design_1_i/WEIGHT_INPUT_PROVIDER_0/inst/selection_inst/sel_reg_reg[1]_i_2/O, cell design_1_i/WEIGHT_INPUT_PROVIDER_0/inst/selection_inst/sel_reg_reg[1]_i_2. This is not good design practice and will likely impact performance. For SLICE registers, for example, use the CE pin to control the loading of data.
I checked the source code (given below - from selection.v file) for the selection_inst which leads to this issue. But I can't find any gated clock there. Can anyone please help me to find out the issue and improve it ? And please inform me if there are any bad coding techniques I used.
module selection(clk, rst, sel, ready, valid, sel_0, sel_1, sel_2, SEL_EN, count_data_start, count_data, count_data_max, weight_count_max_enable, count_data_max_enable);
input wire clk, rst;
input wire ready, valid;
output wire [1:0] sel;
wire trans_enable;
reg [1:0] sel_reg;
reg [3:0] count_reg;
input wire [1:0] sel_0, sel_1, sel_2; // selection made under FORWARD PASS CONVOLUTION or BACKWARD PASS LOCAL GRAD CONVOLUTION
input wire SEL_EN;
// COUNT WEIGHT DATA
input wire count_data_start;
input wire [7:0] count_data_max;
output reg weight_count_max_enable;
output reg count_data_max_enable;
output reg [7:0] count_data;
assign sel = sel_reg;
assign trans_enable = ready & valid;
always @(*) begin
if(count_data_max_enable) weight_count_max_enable <= 1'b1;
else weight_count_max_enable <= 1'b0;
case(count_reg)
4'd0: sel_reg <= sel_0;
4'd1: sel_reg <= sel_0;
4'd2: sel_reg <= sel_0;
4'd3: sel_reg <= sel_1;
4'd4: sel_reg <= sel_1;
4'd5: sel_reg <= sel_1;
4'd6: sel_reg <= sel_2;
4'd7: sel_reg <= sel_2;
4'd8: sel_reg <= sel_2;
4'd9: sel_reg <= sel_0;
endcase
end
always @(posedge clk, negedge rst) begin
if(~rst) begin
count_data <= 8'd0;
count_reg <= 4'd0;
count_data_max_enable <= 1'b0;
end
else if(count_data_start) begin
count_reg <= 4'd0;
count_data <= 8'd0;
end
else begin
if(count_reg == 4'd9 && trans_enable) begin
count_reg <= 4'd1; // CLOCK AT COUNT_REG = 9 SHOULD NOT BE WASTED
end
else if(trans_enable) begin
count_reg <= count_reg + 1'b1;
end
else begin
count_reg <= count_reg;
end
count_data <= (trans_enable && ~count_data_max_enable) ? count_data + 1'b1 : count_data;
if(count_data == count_data_max && count_data_max != 8'd0) count_data_max_enable <= 1'b1;
else count_data_max_enable <= count_data_max_enable;
end
end
endmodule
Following are the important verilog modules of the complete codebase for the IP I created.
For implementation what I did was first I created the IP and then created a block design containing zynq processor and connected the IP, and run the implementation. It was completed successfully but ends up with above warning.
11-08-2020 05:25 AM
A real quick lint check using Verilator (it's much faster than Vivado) reveals two problems with selection.v:
Dan
11-08-2020 05:25 AM
Dan
11-08-2020 07:39 AM
You have a combinatorial process, that always @(*). Because there is no clock, data is registered by the conditions (gates). That's not the best by far... I'd suggest making that process synchronous to a clock. And obviously, include all cases for the 'case' statement to not inferring latches.
11-08-2020 01:09 PM - edited 11-08-2020 01:15 PM
@dgisselq Thank you for answering my issue.
The main issue I had was having an inferred latch that comes with avoiding default case in the combinational logic. And other issues you mentioned will also be corrected to follow proper coding techniques.
11-08-2020 01:13 PM
