Generate Labeled Implemented Design
I would like to make this view labeled, meaning that I need Vivado to show me something similar to the floorplanning. To make allocate the different design components (eg. ALU, Controller, other instantiated block in my design).
I need to see where each block of my design is majorly congested.
Re: Generate Labeled Implemented Design
Hi @asobeih ,
If you are looking for reporting congestion metrics, then open implemnted design-> Device View-> Right click and goto Metrics:
Raj
Hi @asobeih ,
If you just want to visually see where the primitives for a module have been placed then select the module in the netlist view and select Highlight Leaf cells.
Before:
After
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
