Get Vivado to stop using AppData?
Vivado keeps trying to use AppData for temporary files, which it can't write to successfully due to what I think is some kind of antivirus measure.
How do I disable Vivado from doing anything in /AppData?
Windows 10 x64.
Re: Get Vivado to stop using AppData?
I figured it out, I think.
https://www.xilinx.com/support/answers/51659.html
So it looks like the design was simply too big for Vivado to handle without forcing it to use more memory (on Windows, Linux doesn't have this behavior).
Running with start vivado -jvm Xmx4g allowed Vivado to get through synthesis/implementation without issue. Hooray!
Hi .@.@.v.@.@.
To customize the Launch directory, you can:
1. right-click on the Vivado Icon -> More -> Open File Location
2. Once in the Icon folder, double-click the Icon and select "Shortcut" tab. The "Start In" directory can be changed then.
Another option is to use a Windows command prompt.
1. Start Key "cmd"
2. Navigate to Vivado/<version> installation area.
3. enter "settings64.bat"
4. Navigate to the desired start directory and type "vivado"
This did not work.
[Common 17-37] Directory in which file u_mig_ddr4_phy_phy.xdc is to be written does not exist [C:/Users/204289/AppData/Local/Temp/5840/project_1/u_ddr4_mem_intfc]
Hi .@.@.v.@.@. ,
You can try changing the TEMP and TMP Environment variables to a location other than AppData and see if it helps.
Even with my local administrator account it looks like those variables were not getting propagated properly (even after opening a new CMD window - weird, maybe some Group Policy change?)
So I made a batch file to force the issue:
set TMP=E:\TEMP
set TEMP=E:\TEMP
call D:\Xilinx\Vivado\2016.4\settings64.bat
start cmd /k echo "Read to run Vivado."
Then ran "vivado.bat" and TMP/TEMP both now point to E:\TEMP, as I wanted.
However the issue persists like so:
[Common 17-37] Directory in which file u_mig_ddr4_phy_phy.xdc is to be written does not exist [E:/TEMP/18672/project_1/u_ddr4_mem_intfc]
VIVADO IS SUPPOSED TO MAKE THAT DIRECTORY! It's a sub-module generated from the MIG IP; what in the world is going on?!
.@.@.v.@.@.
Thanks for the update. Can you please close this thread by marking your above post as "Accept as Solution"
--Syed
