Get stuck in opt design (phase5 sweep)
I am using Vivado 2016.4 to run a axi design. The project was stuck in opt_design, phase5 sweep. I looked at the log file and there is no error. Here are the log file and some warnings. I wonder if there any method to figure out the error or the details of implementation. Thank you.
Hi @kirito0816 ,
Firstly i will suggest you to migrate to latest Vivado version, if there is no limitation at your end.
And for workaround try removing the sweep option from opt_design phase, check the below AR# link for that:
https://www.xilinx.com/support/answers/53845.html
Raj
@kirito0816
How long did you wait to confirm that the tool got stuck during sweep stage? Check timestamp of runme.log file present in impl_1 folder and check if the time is regularly getting update. Also can you share the log file after running with verbose option with opt_design command.
--Syed
I have to use version 2016.4. And I will try to remove the sweep option. It will take 10 hours to see the result. Thank you.
The timestamp of runme.log is 2019/12/10 0:03 and I post the question at about 9:50am.(about 10 hours) I will try to use this method and post the result. Thank you.
Hi @kirito0816 ,
Does removing sweep option helped to bypass the issue?
Raj
@rshekhaw
Thank you. There is a little change in opt_design. There is one more message. But it is still in opt_design. I am still waiting.
@rshekhaw The opt_design passed! And there comes a new error in place_design.
[DRC 23-20] Rule violation (NDRV-1) Driverless Nets - Net pcie0/inst/pcie4_ip_i/inst/pcie_4_0_pipe_inst/pcie_4_0_e4_inst_n_3698 are undriven.
I wonder if this is related with previous option in opt_design? Thank you.
 Hi @kirito0816 ,
After opt_design run the below command to check whether it gives some more information on errors or not.
place_design -nets [get_netspcie0/inst/pcie4_ip_i/inst/pcie_4_0_pipe_inst/pcie_4_0_e4_inst_n_3698]
Raj
Hi, @rshekhaw
I tried this commend
place_design -nets [get_nets pcie0/inst/pcie4_ip_i/inst/pcie_4_0_pipe_inst/pcie_4_0_e4_inst_n_3698]
but it said that the "-nets"is not an option.
[Common 17-170] Unknown option '-nets', please type 'place_design -help' for usage info.
I tried "place_design -help" and the options are
"-directive <arg>, -no_timing_driven , -timing_summary, -unplace, -post_place_opt, -quiet, -verbose"
Thank you.
Hi @kirito0816 ,
Apologies my bad.
Will it be possible for you to sghre the post opt dcp with us?
Also in opt design device view search for that particular net and check for the proper driver for that net, either it is getting trimmed of or not.
Raj
