Help with Coregen: MMCM parameter options
I am trying to create a 5 MHz clock with enable using the MMCM. I have a 60 MHz clock in my design, but I am not sure what to put for some parameters in coregen.
On Page 1: What should I put for "Input Jitter" and source (Single Ended Clock Capable Pin, Differential Clock Capable Pin, Global Buffer, No Buffer)?
On Page 2: What should I put for "Drives" (BUFGCE, BUFHCE)?
I understand the source might depend on the particulars of the input clock, but I really don't know where to start looking, so I would appreciate any help. I'm sure I missed some information that is required, so please explain what you need to know to help me. Thank you so much.
Scholar austin
Re: Help with Coregen: MMCM parameter options
Yes,
If it is needed in more than one region, that makes it global.  Since you already have the clock in your design, and if it is already on a BUFG, the output signal name may now be connected to something else.
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
Well,
What do you want?
A 60 MHz clock input comes from somewhere, and has some jitter.
I would put in 50 ps, if you do not know, as cyrstal oscillator sources are from 25ps to perhaps as much as 100ps, depending on their quality.
As for what the output is driving:  is it to be used globally, locally?  A BUFG is the global buffer.  Look at thge MMCM user's guide for the details.
http://www.xilinx.com/support/documentation/user_guides/ug362.pdf
Austin Lesea
Principal Engineer
Xilinx San Jose
Thanks Austin. I found this in my .PAR file. clkm is my MMCM input clk so I should set the source as global buffer, right?
Generating Clock Report
|        Clock Net    |   Resource   |Locked|Fanout|Net Skew(ns)|Max Delay(ns)|
|                clkm |BUFGCTRL_X0Y31| No   | 4612 |  0.455     |  2.035      |
I read the document and it was pretty good information. I'm pretty sure I have available BUFG's, but the clock is only used in one component, although it is about 40% of the whole design. What is the difference between global vs local clocks though? I believe the clock will be needed in more than one region, so does that make it global?
Scholar austin
Yes,
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
It is fanned out (connected) to over 4,000 other elments (loads).
Austin Lesea
Principal Engineer
Xilinx San Jose
I have gotten an error when trying to synthesize in PlanAhead. If my clock buffer is going to be used in a reconfigurable partition, then I must choose BUFHCE, not BUFGCE?
Scholar austin
Yes.
Reconfigurability adds a number of restrictions.
Austin Lesea
Principal Engineer
Xilinx San Jose
Any other restrictions that I need to be aware of ahead of time? I wish to have a dynamic partition covering multiple clock domains. Am I better off putting the buffer as a BUFGCE in the static logic or having a BUFHCE in the reconfigurable logic?
Scholar austin
I recommend putting the basic structure stuff in the non-reconfigurable part.
IO, clocks, etc. are best all kept static.
Change the logic all you wish.
That is the simplest and easiest to do, and will lead tio the fewest headaches and problems.
Austin Lesea
Principal Engineer
Xilinx San Jose
