Visitor kobe0294
How Constraining Routing not route through a certain CLB?
Hi, I am trying to find a method to constrain PAR to not route through or switch box of a CLB. You can block PAR from placing any Logic onto a CLB by using the constraints CONFIG PROHIBIT..Basically it leaves the slices in the CLB "empty"...But PAR uses the switch matrix of such an "empty" CLB to route through to other slices. Is there any other way to block PAR from using switch matrix of such "empty" CLBs for routing. Thanks in advance!!
Re: How Constraining Routing not route through a certain CLB?
@kobe0294,
draw a pblock for dummy logic and set contain_routing property on the pblock. Check page 173 in below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug912-vivado-properties.pdf#page=173
--Syed
Visitor kobe0294
More info for your reference:
we have a V7-2000T FPGA IC, and found that the power supply for BANK39 was short,
We want re-use this FPGA , so need to place and route bypass the damaged area.
@kobe0294,
--Syed
