How can I get basic ucf of Xilinx ?
Hi.
I'm trying to implement to the Xilinx XC7K480T-2FFG901I.
But I want to know how can I get the  basic Xilinx XC7K480T UCF?
In Vivado, it is the xdc file for constraints (UCF was used with ISE, which is no longer used with devices in 7 series and newer),
Constraints are device, design, printed circuit board, specific,  There is no set of constraints for a given device (part-package).
There are board files for various boards available, which may serve as a source for your design.  For example for the Virtex-7 XC7VX485T-2FFG1761C:
https://www.xilinx.com/products/boards-and-kits/ek-v7-vc707-g.html#documentation
I see no readily available boards for the  XC7K480T-2FFG901I device....
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi @sylee119,
UCF is not supported in Vivado, only XDC is.
There is a Migration Guide UG911 which is available to ease the changeover:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug911-vivado-migration.pdf
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
