v_tihhomirov
How can I leave some out ports open (floating, unconnected) in UCF?
There is an example design in Xilinx, which connects 60 GPIO pins of Zync Processing System to different pins of FPGA. I want the LED pins to be driven by a different, custom core. I can replace the LED connections from Zync PS to my core. But, Zync will still drive corresponding pins and the map will connect them to arbitrary ports of FPGA, I believe. Can I tell the mapper that this is unncecessary?
driesd
Hi Tihhomirov,
here are the 3 possibities:
if you don't constrain all I/O ports of your toplevel design, the Xilinx tools will choose and pick a location for you.
This is potentially dangerous and not recommended.
However, you can have I/O ports and constrain them in UCF which you don't use. The Xilinx tools will then tristate these unused ports.
It will not be allowed to have I/O constraints in the UCF which do not exist in your toplevel. The tools should normally error out on these.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
blaine
You should consider using Vivado for new designs. It is our recommended tool for Zynq designs.
John
