How can I make success implementation using DDR4 source without DDR4 xci IP
Hi.
How can I make success implementation using DDR4 source without DDR4 xci IP?
here is my sequence.
1. I make a project and create MIG DDR4 IP (default ddr4_0.xci)
2. I make example design and change xdc pin mapping.
   - The pin mapping is board dependent so can not change.
3. Run synthesis and open synthsis design
4. I export constraints file and change xdc file
5. I remove xci file and add MIG source files
 (default example design path) to ddr4_0_ex -> ddr4_0_ex.srcs -> sources_1 -> ip -> ddr4_0 ->
       Add files
             1. rtl -> ip_top -> (ddr4_0_ddr4_mem_intfc.sv, ddr4_0_ddr4.sv, ddr4_0.sv)
             2. ip_0 -> ddr4_0_microblaze_mcs.xci
       Add directories
            1. rtl -> axi
            2. rtl -> axi_ctrl
            3. rtl -> cal
            4. rtl -> clocking
            5. rtl -> controller
            6. rtl -> ui
            7. ip_1 -> rtl
Then, synthesis is successful but Implementation generate error!!
-  the error message is BITSLICE error because constraint conflict
How can I get constraints file for synthesis and Implementation with MIG source files?
Re: How can I make success implementation using DDR4 source without DDR4 xci IP
Hi @dh0414.lee
It is highly recommended to add IP .xci file to the project rather than the RTL source files or dcp. Please have a better look at this AR:
https://www.xilinx.com/support/answers/69690.html
Rohit
Rohit
