Visitor sylee119
How do I prevent ISE from automatically using BUFG in designs?
Dear All,
How do I prevent VIVADO from automatically using BUFG in designs?
My VIVADO is 2014.4.1
Can I do it in the UCF file?
Re: How do I prevent ISE from automatically using BUFG in designs?
Hi @sylee119,
You can Apply (*CLOCK_BUFFER_TYPE  = "none" *) in RTL  to prevent clock buffer on any clock port.
The CLOCK_BUFFER_TYPE attribute can be placed on any top-level clock port. It can be set only in the RTL. It is not supported in XDC.
You can check the examples in UG901 page 36: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug901-vivado-synthesis.pdf
UCF files are used for ISE tool. XDC files are used for Vivado.
You may also try using the below setting to disable the buffer insertion on all clock nets.
set_param logicopt.enableBUFGinsertCLK 0
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Hi @sylee119,
hemangd
hemangd
