How to add BUFGCE_HDIO to a Pblock
How do I add this BUFGCE_HDIO to my Pblock?
SwimTeam
@swimteam
I dont think you can add a clock buffer to specific Pblock. The tool will place the BUFG based on its loads.
You can lock the BUFGCE using either LOC constraint or CLOCK_REGION constraint.
--Syed
