How to assign pins to data bus in ucf file
Hi!
     I got an 16 bit data A(15:0) which I want to take out as output from my FPGA xc2Vp30 board. Can anyone tell me how to assign pins for the data bus in ucf file?
Milan
The format is:
NET <SIGNAL_NAME> LOC = <PIN#>;
e.g.
NET  "ddr2_dq[0]"                                LOC = "C20" ;       #Bank 23
More information is available here:
http://toolbox.xilinx.com/docsan/xilinx10/books/docs/cgd/cgd.pdf (Constraints Guide)
There are also many examples in the reference designs for some of the boards, e.g. ML300, ML405, ML505,Spartan-3A Starter Kit, etc. e.g.
http://www.xilinx.com/products/boards/ml505/reference_designs.htm
bt
The format is:
e.g.
bt
Thanks a lot bt. It worked.
Milan
