How to retain same Synthesis/PnR options among multiple runs ?
Hi Experts,
I have project_1 with synth_1/impl_1 created with a script project_1.tcl , which has  all synthesis options and PnR directives set for timing closure.
When I create a new run synth_2/impl_2 in GUI ,  these  options and directives are not forwarded from the parent run to the new run but will have the Vivado Default settings.
How can I retain same synthesis  options among multiple runs created ?
Thanks and Regards
Parth
Hi @partha_g81 ,
Since you are using script flow, please take a look at the command copy_run.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug835-vivado-tcl-commands.pdf#page=216
Hope this helps
Hi, @partha_g81 ,
Please try the below flow:
1. In the Right-click menu of the target run, select "Save As Run Strategy..."
2.  Save the strategy with a name.
3. Create a new run, and select the new created strategy.
Hi @partha_g81 ,
Hope this helps
