austinkim
How to run IDR Flow in Vitis 2021.1?
Hello.
I want to use IDR Flow in vitis 2021.1.
In vivado, it was successful with a simple mouse click.
What should I do with Vitis's RTL kernel flow?
Please let me know if you have a manual that I can refer to.
Thank you.
syedz
@austinkim
we currently do not support IDR for Vitis. It is only supported from Vivado 2021.1.
--Syed
hongh
v++ -link command can link all different kinds of Kernel(C, C++, OpenCL™ C, and RTL) and generate xclbin file.
Please refer to the "--vivado.impl.strategies" content in the below link:
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/vitiscommandcompiler.html?hl=--vivado.impl.strategies
austinkim
Thank you for your answer.
But that's not the answer I'm looking for.
As you know IDR (Intelligent Design Runs) is a feature that came out in 2021.1.
I wonder why you are showing the document of 2020.2.
There is no way to use IDR anywhere in the link you wrote.
The answer I want is an example of using IDR Flow in Vitis 2021.1.
Maybe "strategy=all" does the same thing as IDR?
Does that mean the IDR process is the process of finding the optimal "impl strategy"?
Your answer rather confuses me.
What I want to know is the title. Write again.
syedz
@austinkim
--Syed
austinkim
Thanks for the clear answer.
I wish IDR flow was applied in Vitis.
