IOB=TRUE fails
I would like to know what are the requirements for using IOB=TRUE constraint on a register. I have not found any hints in the ug* documents.
I am getting warnings like this:
CRITICAL WARNING: [Place 30-73] Invalid constraint on register 'i_system_wrapper/system_i/sc_fxgen_1/U0/fxout2_reg[0]'. It has the property IOB=TRUE, but it is not driving or driven by any IO element.
WARNING: [DRC PLIO-6] Placement Constraints Check for IO constraints: Invalid constraint on register i_system_wrapper/system_i/sc_fxgen_1/U0/fxout2_reg[0]. It has the property IOB=TRUE, but it is not driving or driven by any IO element.
The register in question is defined as
signal fxout2 : std_logic_vector(15 downto 0);
and used for nothing else than writing to some GPIO ports (the PMOD-GPIO ports of a ZCU102). The idea is to minimize skew over the port lines by the IOB constraint.
Any advice is welcome.
Thank you, and best regards,
Erik
Re: IOB=TRUE fails
@e_heinz
The common issue is due to not having a single net connection between IO port and flop. Check this AR which might be helpful:
https://www.xilinx.com/support/answers/66668.html
Check page 244 in below user guide to know syntax details with examples:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug912-vivado-properties.pdf#page=244
Can you show us the post-synthesis connection between IO port and the flop connected to it?
--Syed
Re: IOB=TRUE fails
@e_heinz
--Syed
Re: IOB=TRUE fails
@e_heinz
Be sure to note from references given by syedz that IOB=TRUE can be placed on either a port or on a register.  When placed on a port, it will pull a register attached to the port into the IOB.
Cheers,
Mark
Re: IOB=TRUE fails
Thanks for the valuable responses.
The problem was indeed, that the register was not directly connected to IO. I had not been aware of the fact, that the port definition of the VHDL module produces a register on it's own:
When I apply the IOB constraint to the port register fx_reg, everything works as expected.
Erik
Re: IOB=TRUE fails
Erik,
This is not entirely correct.  What's happening is the following.  When you assign a value to the port inside a VHDL clocked process then you get a register which has the name of the port.
Also, I notice that you originally tried to set IOB=TRUE on fxout2_reg(*).  That is, you thought that fxout2_reg(*) was driving the port - but it is driving the port through a LUT.  It is bad practice to drive a port from/through a LUT because you will be sending glitches out of the FPGA.  Make sure you drive ports directly from a register.
Cheers,
Mark
