IOBUF removed
Hi!
When running boundary scan test on a board with a Xilinx FPGA I want an IO pin to be defined as input/output pin. I have tried to used the IOBUF but it is removed during the MAP process. I have also tried to use the KEEP constraint on the 3-state enable signal but it is still removed. How could this be done?
Output from Map process:
The signal "enable" is unused and has been removed.
 Unused block "XST_VCC" (ONE) removed.
Unused block "IOBUF_inst/OBUFT" (TRI) removed.
The code looks like this:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
library UNISIM;
use UNISIM.VComponents.all;
entity top_level is
    Port ( in_clk : inout  STD_LOGIC;
              out_clk : out STD_LOGIC);
end top_level;
architecture Behavioral of top_level is
signal enable : STD_LOGIC;
attribute keep : string;
attribute keep of enable: signal is "TRUE";
begin
    IOBUF_inst : IOBUF
    port map (
        O => out_clk, -- Buffer output
        IO => in_clk, -- Buffer inout port (connect directly to top-level port)
        I => '1', -- Buffer input
        T =>  enable -- 3-state enable input
   enable <= '1';
end Behavioral;
please try to add save flag "s"
in the ucf for in the code
please see Constrant guide for detailed info
Thanks for your reply. I can't understand now how I could miss that constraint.
