ISE14.4 summary didn't updata after p&r
ISE14.4 summary didn't updata after map and p&r. I clearup project and re-run all ,there also has no summary. but the message(map ,p&r) updated normally.Just can not see summary and detailed report. i don't know why.
Hi @gg9132qq,
- Can you please attach a screenshot indicating this issue?
- Is this seen for a specific design or for all runs? Try example projects to check if the same issue is seen.
- Which OS are you using?
- Can you try the same design in ISE 14.7?
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
Hi @gg9132qq,
