Visitor m.valeyrie
Implementation Complete but many unroute nets
Hi every one,
I'm facing something new. I previously correctly implemented my design without any problem. For some day, in every design I try to re run implementation without any changement, there is many nets unrouted.
I tried many configuration to run implementation, I change my design, without any success.
I attache you synthesized schematic, which is good, and implemented schematic.
If you have any idea, I'm very interested.
Note that differential pins have always been constrained to the same physical pins (to FMC) and should go straight to SelectIO IP correctly configure to accept LVDS.
I'm using Vivado 2017.4, targetting zedboard.
 I thank you in advancefor your help guys.
Re: Implementation Complete but many unroute nets
@m.valeyrie,
I see the following warning during sweep stage of opt_design:
Phase 3 Sweep
WARNING: [Opt 31-163] Instance falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_0/inst/pins[0].iserdese2_slave with type ISERDESE2 and SERDES_MODE=SLAVE will be removed because its outputs are unobservable. If the associated master SERDES requires the slave and is not removed, an error will be issued when generating the bitstream. To avoid this message and the removal of the slave SERDES (assuming it is needed by the master), please add a DONT_TOUCH property to it before running opt_design.
WARNING: [Opt 31-163] Instance falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_1/inst/pins[0].iserdese2_slave with type ISERDESE2 and SERDES_MODE=SLAVE will be removed because its outputs are unobservable. If the associated master SERDES requires the slave and is not removed, an error will be issued when generating the bitstream. To avoid this message and the removal of the slave SERDES (assuming it is needed by the master), please add a DONT_TOUCH property to it before running opt_design.
WARNING: [Opt 31-163] Instance falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_2/inst/pins[0].iserdese2_slave with type ISERDESE2 and SERDES_MODE=SLAVE will be removed because its outputs are unobservable. If the associated master SERDES requires the slave and is not removed, an error will be issued when generating the bitstream. To avoid this message and the removal of the slave SERDES (assuming it is needed by the master), please add a DONT_TOUCH property to it before running opt_design.
Phase 3 Sweep | Checksum: 1f95010f3
Applying DONT_TOUCH attribute helped to retaining the cells and the design was successfully routed.
set_property DONT_TOUCH 1 [get_cells {falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_0/inst/pins[0].iserdese2_slave}]
set_property DONT_TOUCH 1 [get_cells {falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_1/inst/pins[0].iserdese2_slave}]
set_property DONT_TOUCH 1 [get_cells {falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_2/inst/pins[0].iserdese2_slave}]
However, Now I got the following error during bitstream generation:
ERROR: [DRC REQP-105] enum_DATA_RATE_DDR_connects_CLK_ACTIVE_connects_CLKB_ACTIVE: falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_0/inst/pins[0].iserdese2_master: The use of attribute DATA_RATE set DDR requires connectivity for the CLK and CLKB input pins.
ERROR: [DRC REQP-105] enum_DATA_RATE_DDR_connects_CLK_ACTIVE_connects_CLKB_ACTIVE: falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_0/inst/pins[0].iserdese2_slave: The use of attribute DATA_RATE set DDR requires connectivity for the CLK and CLKB input pins.
ERROR: [DRC REQP-105] enum_DATA_RATE_DDR_connects_CLK_ACTIVE_connects_CLKB_ACTIVE: falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_1/inst/pins[0].iserdese2_master: The use of attribute DATA_RATE set DDR requires connectivity for the CLK and CLKB input pins.
ERROR: [DRC REQP-105] enum_DATA_RATE_DDR_connects_CLK_ACTIVE_connects_CLKB_ACTIVE: falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_1/inst/pins[0].iserdese2_slave: The use of attribute DATA_RATE set DDR requires connectivity for the CLK and CLKB input pins.
ERROR: [DRC REQP-105] enum_DATA_RATE_DDR_connects_CLK_ACTIVE_connects_CLKB_ACTIVE: falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_2/inst/pins[0].iserdese2_master: The use of attribute DATA_RATE set DDR requires connectivity for the CLK and CLKB input pins.
ERROR: [DRC REQP-105] enum_DATA_RATE_DDR_connects_CLK_ACTIVE_connects_CLKB_ACTIVE: falcon_design_3_wrapper_inst/falcon_design_3_i/selectio_wiz_2/inst/pins[0].iserdese2_slave: The use of attribute DATA_RATE set DDR requires connectivity for the CLK and CLKB input pins.
Upon checking the connection, found that the CLK and CLKB pins of ISERDES are connected GND. Please fix this.
--Syed
Hi @m.valeyrie. Is the output of the report_route_status available? Knowing the pin-to-pin connectivity would help.
Also, from the placed design (not routed yet), can the individual net be routed? Below is an example of the command:
route_design -nets [get_nets <net_that_has_routing_errors>]
@m.valeyrie,
Can you please share runme.log file present in <project>/<project>.runs/impl_1 folder? If possible, also share the post synthesized design checkpoint file (.dcp).
Open the synthezied design and run the following command to generate post synth dcp file:
write_checkpoint ./post_synth.dcp
--Syed
Visitor m.valeyrie
Hi @syedz,
Thanks for your reply.
Please find in attachement  runme.log and checkpoint file.
Maxime
Visitor m.valeyrie
Hi @marcb,
Thanks for your answer.
Here is the report_route_status:
Design Route Status
                                                              :      # nets :
# of logical nets..........................       :        1961 :
# of nets not needing routing.......... :        1212 :
# of internally routed nets........         :        1212 :
# of routable nets.....................          :         749 :
# of fully routed nets.............             :         749 :
# of nets with routing errors..........    :           0 :
When I run route_design -nets [get_nets <net_that_has_routing_errors>] comand, I get:
route_design -nets [get_nets <ch_a_n[0]>]
WARNING: [Vivado 12-507] No nets matched '<ch_a_n[0]>'.
Command: route_design -nets [get_nets {<ch_a_n[0]>}]
Attempting to get a license for feature 'Implementation' and/or device 'xc7z020'
INFO: [Common 17-349] Got license for feature 'Implementation' and/or device 'xc7z020'
INFO: [DRC 23-27] Running DRC with 4 threads
INFO: [Vivado_Tcl 4-198] DRC finished with 0 Errors
INFO: [Vivado_Tcl 4-199] Please refer to the DRC report (report_drc) for more information.
Running DRC as a precondition to command route_design
Empty tcl collection of nets.
INFO: [Common 17-83] Releasing license: Implementation
8 Infos, 1 Warnings, 0 Critical Warnings and 0 Errors encountered.
route_design completed successfully
Is this a licence problem ?
@m.valeyrie,
Phase 3 Sweep
--Syed
Visitor m.valeyrie
Hi @syedz,
Thanks for these informations.
I applyed "DONT_TOUCH" command and nets are fully routed. I found a new timing problem then I can't see the error in bitstream generation for now. I'm working on it, then please considere my problem solved.
Thank you :)
Maxime
