Zayn22221
Implementation Error:[Chipscope 16-213] The debug port 'm3/probe22' has 32 unconnected channels (bits). This will cause errors during implementation.
I am trying to run the implementation for a code but getting this error during implementation.
hongh
Please check the synthesized design netlist to know why the reported ILA's probe ports m3/probe22 are unconnected.
If you don't need the probe, please remove it. If the connected signal are removed, you need to find why the signals are removed.
